skunkyone11 0 Posted ... I have gluetun and qbittorrent setup and working successfully thanks to other posts in the forum but I’m running into a problem. When the vpn reconnects in gluetun, I need to manually restart qbittorrent otherwise I’m not connectable (firewalled). Is there a way to do this automatically? Quote Share this post Link to post
Staff 10464 Posted ... 11 hours ago, skunkyone11 said: I have gluetun and qbittorrent setup and working successfully thanks to other posts in the forum but I’m running into a problem. When the vpn reconnects in gluetun, I need to manually restart qbittorrent otherwise I’m not connectable (firewalled). Is there a way to do this automatically? Hello! In a GlueTun-based environment, please be aware of the following issue, that's considered by some people a GlueTun bug: https://airvpn.org/forums/topic/63708-gluetun-port-forwarding-works-for-an-hour/ The thread includes suggestions to significantly mitigate the problem exclusively through GlueTun specific configuration. Kind regards Quote Share this post Link to post
