jimdasaint
Setting up VPN and WaterRoof Firewall with
As a new member I have set up the AirVPN connection on my MAC OSX 10.6 running Tunnelblick. I have also downloaded WaterRoof in order to prevent any IP leaks when VPN service drops based on an earlier recommended support board comment.
However I have no idea how to configure WaterRoof in order to protect my uTorrent activity.
Do you have any readily available configuration files for WaterRoof or tutorials available?
I need help with setting up the following functionality:
1. uTorrent would only work through the active VPN connection otherwise it would be blocked. No need to quit the software just block in and out traffic.
2. All other software on the machine can still use VPN or non-VPN connection regardless of VPN connection status.
Thanks,
jim
