jacksonbeach
ANSWERED Port Forwarding not working in Pfsense
I'm having some trouble with my current configuration, and I'm not sure what's going wrong. Here's my setup:
  • Firewall: I'm using PFsense with the necessary ports open and NAT configured properly. (For now, it's open to the world for simplicity, but I'll restrict it later.)
  • VPN: Deluge is running and shows the AirVPN IP as expected.
  • Environment:
    • OS: Debian
    • Layered Stack: CasaOS -> Deluge (Docker)
Despite this setup, something seems to be off. Deluge is running, and the AirVPN IP appears correctly, but connections don't seem to function as intended.
Any idea of what am I doing wrong? Without the VPN was working fine the port forwarding locally
Edited ... by jacksonbeach
I just make it work, I changed the port locally for the same using in the VPN, changed it in the docker, rebooted everything and now it works.
