ANSWERED A little help with adapters
I am trying to find the best adapter for speeds in torrenting.
I had many AED decrypt errors in eddie in Windows Server with default configuration that solved making the move to TCP protocol. But speeds are slow too.
I have tested every possible choice in eddie and my conclution is:
OpenVPN TCP 80 (if your ISP applies caps or blocks)
and using ovpn-dco in eddie settings.
I have no leaks in ipleak.net. Is it safe for torrenting? thnks in advance, i am noob. I have seen 400Μmbit speeds with this configuration.
The performance you get is good, especially if you consider that you have packet errors when you connect over UDP. The fact that you get much better throughput on a specific port with the same protocols hints to traffic shaping by the ISP.
The setup is safe provided that you add some measure against traffic leaks, please make sure that you enable Network Lock if you run AirVPN software. On top of that, you may also consider to bind the torrent software (if a bind option is available in your torrent program settings) to the VPN interface you mentioned.
