A1rX 0 Posted ... Hi. I'm new to mac and Airvpn after using PC and another VPN with Qbit. I hope these steps I've taken to torrent with Qbit are correct, but if I have misstepped, please correct me. Firewall settings: 1.Block all incoming connections: deselected - Eddie: Allow incoming connections - qBit: Allow incoming connections 2. Automaticallt allow built-in softwarre to receive incoming connections: selected 3. Automatically allow downloaded signed software to receive incoming conncections: selected 4. Enable stealth mode: selected. Qbit settings: 1. Behaviour: Untouched; as in, I haven't selected or deselected anything, because I have no idea what it all means. If anyone has recommendations, I would be grateful. 2. Downloads: See 1. 3. Connection: - Peer connetion protocol: TCP and UTP (same as the protocol on my Ports page) - Listening Port: set to the same port on my Ports page) - Use UPnP / NAT=PMP port forwarding from my router: deselected I have not messed with either: Connection Limits, I2p (experimental), Proxy Server, IP Filtering, etc. Speed: Default settings (any recommendations greatly appreciated) 1. Global Rate Limits: - Upload: infinite - Download: infinite 2. Alternative Rate Limits: - Upload: 10 KiB/s - Download: 10 KiB/s Rate Limits Settings: - Apply rate limit to UTP protocol, ticked. - " " " " peers on LAN, ticked. - Apply .... transport overhead, not ticked. BitTorrent: Default settings (any recommendations greatly appreciated) RSS Reader: Default settings (any recommendations greatly appreciated) Web User Interface (Remote control): entirely greyed out. Advanced: Default Settings (any recommendations greatly appreciated). 3. Network interface: Any interface 4. Optional IP address to bind to: All addresses (Q. Is the "::1" my best option, since a ":1" is the number beside my port number on my Ports page? Thank you for reading this and thank you in advance for any advice. On PC, with Proton VPN, I just selected "port forwarding" and added the App number to qBit and binded them. I have learned from reading AirVPN's guides and forums that I should have deselcted "Use UPnP / NAT=PMP port forwarding from my router", alas. Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... On 12/21/2024 at 8:22 PM, A1rX said: - Peer connetion protocol: TCP and UTP (same as the protocol on my Ports page) uTP is generally treated as a throughput inhibitor inside a VPN, disable it. Note that uTP is not UDP. On 12/21/2024 at 8:22 PM, A1rX said: I have not messed with either: Connection Limits You should, though, in accordance to your available bandwidth. On 12/21/2024 at 8:22 PM, A1rX said: - Upload: infinite Limit this to 90% of the upload bandwidth. On 12/21/2024 at 8:22 PM, A1rX said: 3. Network interface: Any interface Always set this to the VPN interface to have something akin to a kill switch. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
A1rX 0 Posted ... On 12/25/2024 at 11:48 AM, OpenSourcerer said: uTP is generally treated as a throughput inhibitor inside a VPN, disable it. Note that uTP is not UDP. You should, though, in accordance to your available bandwidth. Limit this to 90% of the upload bandwidth. Always set this to the VPN interface to have something akin to a kill switch. Thank you, I've applied your suggestions. Seeding is very slow compared to previous VPN Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... On 12/29/2024 at 8:53 PM, A1rX said: Thank you, I've applied your suggestions. Seeding is very slow compared to previous VPN Could have any number of reasons. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
