Spoilage8462
Issue with wrong public IP
I originally posted this in blocked sites warning, but I think it may be more relevant here. I'll see if I can go back and delete that topic.
So, I'm connected to Fang currently. I'm hosting a server that is behind Cloudflare proxy. I've configured the proxy to disallow out-of-country IPs. Here's the weird thing: Cloudflare's block page thinks I'm in Italy. Based on an IP lookup, it's a TOR exit node that it believes I am connected through. I am not using TOR. I'm connected through Air, and every public IP checker I go to (including Cloudflare's own) shows the expected IP - Fang's IP. Any ideas what might be up?
I have the same problem. If the tor service is running in background Cloudflare thinks I'm in the US. I don't know how Cloudflare gets this info.
Apologies for the delay here. I never did figure it out. I changed my network up a bit - I put a DNS server (pihole docker container) in the internal network and routed over to it using tailscale. That means I only access through my personal VPN, so it's not on the live net anymore. This won't work if you need others to access your service, of course.
