Pulse2492
ANSWERED gluetun port forwarding not supported?
gluetun docker log
ERROR VPN settings: provider settings: port forwarding: port forwarding cannot be enabled: value is not one of the possible choices: airvpn must be one of perfect privacy, private internet access, privatevpn or protonvpn
2024-11-17T20:13:01+01:00 INFO Shutdown successful
docker compose
version: "3.9"
services:
  vpn:
    image: qmcgaw/gluetun
    container_name: vpn
    networks:
      proxy:
        ipv4_address: 10.0.0.4
    cap_add:
      - NET_ADMIN
    devices:
      - /dev/net/tun:/dev/net/tun
    ports:
      - 1637:1637/udp
      - 13660:13660/tcp
      - 13660:13660/udp
      - 8096:8096
    volumes:
      - ./:/gluetun
    environment:
      - VPN_SERVICE_PROVIDER=airvpn
      - VPN_TYPE=wireguard
      - VPN_PORT_FORWARDING=on
      - FIREWALL_VPN_INPUT_PORTS=13660
      - WIREGUARD_PRIVATE_KEY=X
      - WIREGUARD_ADDRESSES=X
      - WIREGUARD_PRESHARED_KEY=X
      - WIREGUARD_ENDPOINT_PORT=1637
      - SERVER_COUNTRIES=Netherlands
      - TZ=X
      - DNS_ADDRESS=10.128.0.1
    restart: unless-stopped
@Pulse2492
Since an AirVPN port reserved to an account does not change and since all AirVPN servers support remote inbound port forwarding, GlueTun does not need a specific AirVPN auto port forwarding setup, which is required only for clunky implementations where the port changes at each re-connection and/or port forwarding works only on some servers.
You just need to configure (on both the listening program and the compose file) the port that you previously managed and reserved through your AirVPN account port panel. For more details please check GlueTun documentation.
