Trahald
ANSWERED IOS WireGuard app connection keeps dropping!
I use WireGuard app and downloaded profiles for AirVPN. Problem is connection drops off after certain time and I feel like I have to check if I am connected to VPN or not. Do I need to change some setting in WireGuard app to stay connected all the time?
WireGuard will never consider a connection over and will not try a re-connection when the tunnel is dead. If you want more network management with re-connection attempts after a timeout you can consider AirVPN software for Android, Linux, Mac and Windows.
