Not connected, Your IP: 216.73.216.51
Baxter
Suggested DD-WRT FirmWare for OpenVPN on WRT54GL Linksys Router
Hi all,
I am just a bit wondering, which DD-WRT Firmware Version would be recommended to use in
a WRT54GL V1.1 Router.
I did check the supported router database on their Site, but all FW suggested is from 2009
and if I am not wrong, many updates to OpenVPN itself have been done,
so this may be a reason why I am currently unable to connect to any AirVPN Destination
with the WRT Router itself, but any client I use in my Homenet, is able to build up the connection using the local windows AirVPN Client.
Hence, I would like an answer, which DD-WRT FW will work with theWRT54GL and AirVPN.
Thanks in Advance for your advice,
Baxter
Hi all,
I just like to share my findings of the past days, with much help from this forum I was finally able to have everything setup the way I wanted to.
First of all, what I experienced, getting errors in the form of TLS Handshake TimeOut (the 60sec. ones) und disconnect issues, EVEN with no iptables or firewall rules in effect, is truly the reason of the firmware.
For the WRT54GL V1.1 I use, I found this build working:
DD-WRT v24-sp2 (03/08/12) vpn - build 18687
Just make sure to get the correct build number and the openvpn generic Firmware build.
Second, I had to use these iptables rules in the DD-WRT to get the traffic correctly forwarded.
iptables -I FORWARD -i br0 -o tun1 -j ACCEPT
iptables -I FORWARD -i tun1 -o br0 -j ACCEPT
iptables -I INPUT -i tun1 -j REJECT
iptables -t nat -A POSTROUTING -o tun1 -j MASQUERADE
iptables -t nat -A POSTROUTING -o tap0 -j MASQUERADE
I had to check (using ifconfig) which correct tun device the openvpn client created, for me it was tun1
Hence, I had to adapt the rules for this.
Hope this may be of help to anyone in the future.
Kind regards,
Baxter
Thank you for posting this, I am actually running into similar trouble using v24-sp2 (10/10/09) vpn
(SVN revision 13064)
, in my case however, I have successfully added 3 of the four files. Unfortunatly, the CA.crt would not take for some reason. I assumed the text from the ca.crt file would be applied in the
/Services/VPN/Openvpn Daemon/"Public Server Cert" box. <--Apparently this is a new name given to the CA.crt box.
When the CA.crt code was pasted here, it did not hold after clicking apply. The box just cleared the code. weird...
I was refereed here by support to this thread and started looking around. So far the only place I have found the 18687 build is through the link below, but I do not see a folder for the WRT54GL that was mentioned in this thread... Is there another place I should be looking?
ftp://ftp.dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/2012/03-08-12-r18687/files/
Thanks,
There may be variations in the way the text boxes for the various keys are named among all the iterations of the dd-wrt firmware.
Check this page:  https://airvpn.org/ddwrt/  and see if those instructions match what you see in the particular version you are using.
Hope this helps.
While I get that the router you are using is an old work horse it will good a long way to upgrade to a newer router with more RAM and a better CPU. OpenVPN takes a lot of resources to run well and the W54 just lacks those. For likely $40 or less you could get a much more capable router for VPN usage.
The following build has been tested and it fully works with AirVPN, for Linksys WRT-54GL 1.1:
Also confirmed by Baxter and other people:
https://airvpn.org/topic/6525-suggested-dd-wrt-firmware-for-openvpn-on-wrt54gl-linksys-router/?do=findComment&comment=6612
The newest build you cite has not been tested so far: feel free to try, just keep in mind that it's not been tested yet. See also here to avoid bugged builds:
http://svn.dd-wrt.com/ticket/2536
EDIT:
some additional notes to help you avoid bugged DD-WRT firmwares can be found on this thread:
https://airvpn.org/topic/4292-dd-wrt-not-connecting-on-linksys-e2500-router/?do=findComment&comment=4358
Baxter, it is great that you somehow got it to work. I tried the link of the firmware to 18687 for the wrt54g after a bunch of google searches turned up nothing else for the wrt54gl or a generic build and now I will have to JTAG the effing thing since I can't even ping it now. If you are going to post that you got it working how about you at least do us the courtesy of posting a link to the build that you used.
I can confirm that the 18687 build of DD-WRT works. I was very near to using the wrt54g build and bricking my router until I read joker69's post, so thanks for that.
Here's the direct link to the firmware image file for WRT54GL 1.1, it took quite a bit of work to uncover:
ftp://dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/2012/03-08-12-r18687/files/broadcom/dd-wrt.v24_vpn_generic.bin
I can confirm that this build works with airvpn, although it needs a bit of tweaking. There's a bug in this particular version of the firmware that makes the Hash Algorithm setting revert back to SHA256, but airvpn uses SHA1. Maybe some servers auto-negotiate this, but I needed to force this to SHA1 for it to work.
The following setting needs to be changed in the openvpn.conf file on the router:
auth sha1
I'm still struggling with making this thing apply with a startup script so the setting won't be lost when I reboot, but at least it's working when I add this manually through telnet.
Just a quick thank you and a question...
Firstly, thanks for the suggestion of using build 18687 on my ol' WRT54GL. Got it connecting to AirVPN reliably (as far as I can see, although the Hash Algorithm setting does change on its own as mentioned above - but doesn't seem to matter).
Secondly, is there much of a difference between Baxter's iptables rules and the DD-WRT firewall rules listed on the setup page?
The reason I ask is my connection seems to work with both, and being a noob I don't really know the difference between tun0 and tun1, or why Baxter includes a line for tap0 while the setup page doesn't. If someone could explain this that would be fantastic!
Thanks again.
edit: Actually, looks like Baxter's iptables rules don't work on my system - but the firewall rules on the setup page seem to (for both wired and wireless access). However, I am a little concerned when the log keeps showing lines such as:
20140325 11:31:32 MANAGEMENT: Client connected from 127.0.0.1:5001
20140325 11:31:32 D MANAGEMENT: CMD 'state'
20140325 11:31:32 MANAGEMENT: Client disconnected
20140325 11:31:32 D MANAGEMENT: CMD 'log 500'
Is this a problem? I don't seem to be losing VPN connectivity, but if it's disconnecting and reconnecting so quickly I don't notice that could be a problem. If anyone has any insight I'd love to hear it, otherwise I might try Tomato and see if the result is the same.
