udp_monkey33
Multiple handshake timouts when using WireGuard protocols
Hello all,
I'm still fairly new to all this but I've learned that I can get better speeds with WireGuard protocols than with OpenVPN but with WireGuard I keep getting multiple handshake timeouts back to back. I've already set my my MTU to 1280, use only IPv4 in Eddie and even changed my WiFi channel to a less used one but despite all that it keeps getting timeout and then when it reconnects I have very low speeds. I don't know what to do and  would aprreciate any help.
Eddie_20241104_134626.txt
Looks like a replay, or maybe erratic QoS attempts by the access point. Is it far away from your computer?
@OpenSourcerer, I'm sorry but I don't really know what you mean by that. I don't really know much about all this stuff.
Quote
My router? It's basically straight under my room.
The server that I get connected to from Eddie? Netherlands but I am located in Germany
Basically it looks like this to me: It occurs that some packets are sent "in advance" while a previous flow of packets is still ongoing. It's like you are being sent a row of numbers – 1, 2, 3, 4, 5, 6, 7, 8 – but instead you somehow get the 8 first, then 1-7 after it. This is not liked by either OpenVPN or Wireguard: Both protocols warn you that this is happening and drop all packets that are unorderly received (AEAD decrypt error: Bad Packet ID for OpenVPN, and this nonce warnings for Wireguard). This culminates in packets needing to be resent, leading to throughput cuts, or even disconnections in some softwares.
It could indicate a replay. A replay is, in a simple connection A > B > C, when B is not just passing on packets, but instead resending previously received ones. It could be done by the access point for Quality of Service purposes (like prioritizing certain devices, applications, etc.) or it could be malicious where some device tries to pose as an access point and, while generally relaying packets, checks their content for anything interesting.
Another thing might be that something interferes with the wireless signal and the access point is constantly forced to resend transmissions because it didn't get ACKnowledgments back.
What truly stands out in your case is that you get these messages every five seconds. Can you imagine anything in your network or computer that could do something to the wireless signal (or the devices sending them) every five seconds?
In any case, you can greatly reduce this by using OpenVPN in TCP mode since TCP guarantees orderly transmission and reception. UDP used by Wireguard is a fire-and-forget kinda thing. Of course, it's simply best to check out why those reorderings are happening in the first place :D
I understand now, thanks.
Honestly no, I can't think of anything in my network or computer that would do something like that. But just in case it was in fact on my computer (Windows 11), do you know of a way I could check what might be the culprit?
Also, I tried using OpenVPN in TCP mode but then I get really low download speeds and WireGuard just happens to be way faster. Edited ... by udp_monkey33
Hrm, try Safe Mode with Network Drivers, maybe, connect to the VPN, try to download something?
Because of the guarantees of TCP, it was almost expected to perform so poorly in your case. There is so much interference (with packet ordering or even loss) that it forces constant resends. Can you maybe try a cable connection to rule out wireless being the problem?
Quote
Unfortunately, I can't.
Quote
And what should I be on the lookout for when I do that? Should I be actively monitoring something with a program?
Not even for a short time? It's just for troubleshooting purposes.
It's primarily to rule out interference by any softwares you might be running and not knowing that they are doing something to the connection. Safe Mode doesn't launch those at boot.
Hi! I'm back again.
I still have no access to Ethernet connection unfortunately (would need to carry my whole setup downstairs) but I did manage to give my PC an internet connection via USB tethering in safe mode. But how do I launch the Eddie client while I am in safe mode? I could not accomplish that. Should I add the VPN to Windows 11 directly?
This may be good, too! Do this in Normal Mode.
So do I USB tether and then add the VPN connection to Windows directly in normal mode? Or do I add the VPN to Windows in normal mode and the launch into safe mode to see if there's any interference through any software? Sorry for not understanding.
Also sorry for posting another thread. I just wasn't sure if my reply got through/posted it correctly.
USB tethering in a normal boot.
And no, you cannot add either OpenVPN or Wireguard to Windows directly.
If it's incorrect, I'll move it. People read your thread and all the replies to it, they just don't answer because no ideas come to mind.
Ah so do I just USB tether and see if I get handshake timeouts?
And okay, gotcha.
Edit:
Okay, I just tested to use the VPN with TCP and USB tethering from my phone (same 2.4 GHz WiFi connection) but I still get a timeout. Edited ... by udp_monkey33
Testing USB tethering
What do you mean, timeout with TCP? I thought the problem was invalid nonce errors every five seconds with Wireguard on UDP via WiFi?
I might have misremembered while typing that, sorry.
Either way, I ordered a powerline adapter, see if that helps (provided powerline even works with the wiring of my house).
added "the"
With the powerline adapters set up, I am not experiencing any timeouts anymore, so I am assuming the issue was with WiFi. The only downside with Powerline is that I can't get more than around 8 MB/s, even when not connected to VPN. My next plan is to try MOCA adapters.
It's not an assumption in my opinion, it's the truth. That's why I wanted to rule out wireless before doing anything else.
I suppose so. Is there anything else I should be doing, like maybe looking at the differences in the logs or something, to see what might be the issue with wireless?
At this point I'd say it's a local issue and I strongly recommend ethernet. Troubleshooting wireless issues without being in the vicinity of the wireless signal is pointless :D
Makes sense, I suppose. Thanks anyways!
Happy holidays!
