amabelle
the portable Is genius thing !
All VPN installations with an EXE file simply burden the computer and freeze it , the idea of putting everything in the PORTABLE folder is genius why don't other VPN companies do this? Computers that are LOW MED END is critical !!! there is only a problem with the new version PORTABLE 2.21.8 it is not possible to create a connection to any server It always disconnects and looks for another server in a loop , I found an old version and it works
Edited ... by amabelle
The only difference between portable and installed is the location of files. Not sure what is genius about it.
