owa 0 Posted ... (edited) Hey, I purchased a one month sub today (trialing it before I get rid of PIA). Outside of restarting my computer and made sure Malwarebytes and PIA aren't active, I haven't changed any configs. Edit: I am also running it as administrator and on Windows 11. Not sure what I'm doing wrong, but here's my log: I 2024.11.02 10:48:59 - Session starting. I 2024.11.02 10:48:59 - Checking authorization ... . 2024.11.02 10:49:00 - Using WinTun network interface "Local Area Connection (Private Internet Access Network Adapter)" ! 2024.11.02 10:49:00 - Connecting to Alya (Canada, Toronto, Ontario) . 2024.11.02 10:49:00 - Routes, add 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)". . 2024.11.02 10:49:00 - Routes, add 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)", already exists. . 2024.11.02 10:49:00 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.02 10:49:00 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.02 10:49:00 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.02 10:49:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.02 10:49:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.02 10:49:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.02 10:49:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.02 10:49:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.173:443 . 2024.11.02 10:49:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.02 10:49:00 - OpenVPN > UDP link local: (not bound) . 2024.11.02 10:49:00 - OpenVPN > UDP link remote: [AF_INET]184.75.221.173:443 . 2024.11.02 10:49:00 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.173:443, sid=4d63492b b77451d7 . 2024.11.02 10:49:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.02 10:49:01 - OpenVPN > VERIFY KU OK . 2024.11.02 10:49:01 - OpenVPN > Validating certificate extended key usage . 2024.11.02 10:49:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.02 10:49:01 - OpenVPN > VERIFY EKU OK . 2024.11.02 10:49:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alya, emailAddress=info@airvpn.org . 2024.11.02 10:49:01 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.02 10:49:01 - OpenVPN > [Alya] Peer Connection Initiated with [AF_INET]184.75.221.173:443 . 2024.11.02 10:49:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.170.1,dhcp-option DNS6 fde6:7a:7d20:4aa::1,tun-ipv6,route-gateway 10.8.170.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4aa::1086/64 fde6:7a:7d20:4aa::1,ifconfig 10.8.170.136 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2024.11.02 10:49:01 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.02 10:49:01 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.170.1' . 2024.11.02 10:49:01 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4aa::1' . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.02 10:49:01 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.02 10:49:01 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.02 10:49:01 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.02 10:49:01 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.02 10:49:01 - OpenVPN > interactive service msg_channel=0 . 2024.11.02 10:49:01 - OpenVPN > open_tun . 2024.11.02 10:49:01 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.02 10:49:01 - OpenVPN > Exiting due to fatal error ! 2024.11.02 10:49:01 - Disconnecting . 2024.11.02 10:49:01 - Routes, delete 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)". . 2024.11.02 10:49:01 - Routes, delete 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)", not exists. . 2024.11.02 10:49:01 - Connection terminated. I 2024.11.02 10:49:04 - Checking authorization ... . 2024.11.02 10:49:05 - Using WinTun network interface "Local Area Connection (Private Internet Access Network Adapter)" ! 2024.11.02 10:49:05 - Connecting to Alya (Canada, Toronto, Ontario) . 2024.11.02 10:49:05 - Routes, add 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)". . 2024.11.02 10:49:06 - Routes, add 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)", already exists. . 2024.11.02 10:49:06 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.11.02 10:49:06 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.11.02 10:49:06 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.11.02 10:49:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.02 10:49:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.02 10:49:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.11.02 10:49:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.11.02 10:49:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.173:443 . 2024.11.02 10:49:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.11.02 10:49:06 - OpenVPN > UDP link local: (not bound) . 2024.11.02 10:49:06 - OpenVPN > UDP link remote: [AF_INET]184.75.221.173:443 . 2024.11.02 10:49:06 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.173:443, sid=3f18030c 65f9603f . 2024.11.02 10:49:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2024.11.02 10:49:06 - OpenVPN > VERIFY KU OK . 2024.11.02 10:49:06 - OpenVPN > Validating certificate extended key usage . 2024.11.02 10:49:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2024.11.02 10:49:06 - OpenVPN > VERIFY EKU OK . 2024.11.02 10:49:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alya, emailAddress=info@airvpn.org . 2024.11.02 10:49:06 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512 . 2024.11.02 10:49:06 - OpenVPN > [Alya] Peer Connection Initiated with [AF_INET]184.75.221.173:443 . 2024.11.02 10:49:07 - OpenVPN > SENT CONTROL [Alya]: 'PUSH_REQUEST' (status=1) . 2024.11.02 10:49:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.170.1,dhcp-option DNS6 fde6:7a:7d20:4aa::1,tun-ipv6,route-gateway 10.8.170.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:4aa::1086/64 fde6:7a:7d20:4aa::1,ifconfig 10.8.170.136 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2024.11.02 10:49:07 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2024.11.02 10:49:07 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.8.170.1' . 2024.11.02 10:49:07 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:4aa::1' . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: peer-id set . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2024.11.02 10:49:07 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2024.11.02 10:49:07 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2024.11.02 10:49:07 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.02 10:49:07 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2024.11.02 10:49:07 - OpenVPN > interactive service msg_channel=0 . 2024.11.02 10:49:07 - OpenVPN > open_tun . 2024.11.02 10:49:07 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system. You should be able to create an adapter by using tapctl.exe utility. . 2024.11.02 10:49:07 - OpenVPN > Exiting due to fatal error ! 2024.11.02 10:49:07 - Disconnecting . 2024.11.02 10:49:07 - Routes, delete 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)". . 2024.11.02 10:49:07 - Routes, delete 184.75.221.173/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)", not exists. . 2024.11.02 10:49:07 - Connection terminated. I 2024.11.02 10:49:10 - Checking authorization ... I 2024.11.02 10:49:11 - Cancel requested. ! 2024.11.02 10:49:11 - Session terminated. I was under the impression that the VPN would work out of the box, but I'd need to do some effing around before it was optimized. Maybe that was a mistake? I tried finding setup guides on YouTube but I'm going through a deluge of OpenVPN and Linux stuff. I just want the Windows one to work lmao. Thanks for any help you can provide! Edited ... by owa Share this post Link to post
Tech Jedi Alex 1492 Posted ... 1 hour ago, owa said: . 2024.11.02 10:49:00 - Using WinTun network interface "Local Area Connection (Private Internet Access Network Adapter)" Oh. That.. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
owa 0 Posted ... 19 hours ago, OpenSourcerer said: Oh. That.. Gosh, I feel really silly for not catching that. Thanks so much! It worked like a charm. Share this post Link to post
