Mad_Max
Is there a way to bypass ISP throttle?
Hello
Been using Airvpn for 10 years. and my experience with it has been more than great. I always get 100% of my internet speed while using the vpn. However, last 2 months my ISP has made some new stuff that made a throttle on the VPN, my 200Mbps speed is not 40mbps with vpn only and it the ping gets much higher in games\voip sadly.
I use latest version of Eddie on windows 11 with the default settings, tried changing the protocol but didnt help much.
Any ideas would be highly appreciated
23 hours ago, go558a83nk said:
make sure to try wireguard if you haven't already
Wireguard in Eddie? Or wireguard the app?
Wireguard in Eddie
Had something similar happen with my VPN after an ISP update. Tried changing protocols too, but it didn’t help much. Ended up testing a few settings and even switching servers, which made a small difference.
Edited ... by Tech Jedi Alex
Remove paragraph about some unrelated software sounding like an ad.
