zurahthustra 0 Posted ... I am constantly beeing disconected from Serpentis. See log below. I am using Viscosity on a mac, wifi. Any suggestions on what to do about this? Dec 26 18:01:03: [server] Inactivity timeout (--ping-restart), restarting Dec 26 18:01:03: SIGUSR1[soft,ping-restart] received, process restarting Dec 26 18:01:03: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Dec 26 18:01:03: LZO compression initialized Dec 26 18:01:03: UDPv4 link local: [undef] Dec 26 18:01:03: UDPv4 link remote: 178.248.30.131:443 Dec 26 18:01:03: [server] Peer Connection Initiated with 178.248.30.131:443 Dec 26 18:01:06: TUN/TAP device /dev/tun0 opened Dec 26 18:01:06: /sbin/ifconfig tun0 delete Dec 26 18:01:06: NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure Dec 26 18:01:06: /sbin/ifconfig tun0 10.x.xx.xxx 10.x.xx.xxx mtu 1500 netmask 255.255.255.255 up Dec 26 18:01:06: Initialization Sequence Completed Quote Share this post Link to post
Staff 10386 Posted ... Hello! You could try a connection to a TCP port (and of course try different servers). Kind regards Quote Share this post Link to post
