osalj
ANSWERED Wireguard - access from diffrent vlan
Hey!
I have VLAN49 - subnet 10.49.10.8/29
In VLAN49 I have a LXC host with Debian - 10.49.10.14
I also have another VLAN47 - subnet 10.47.1.0/24
In VLAN47 is my laptop - 10.47.1.248
From the laptop (VLAN47) I have access via ssh, http and ping to LXC with Debian.
On LXC I installed wireguard to connect it to the VPN server AirVPN.
Config below:
[Interface]
Address = 10.xxx.xx.xxx/32,fd7d:76ee:e68f:a993:c2d3:e941:82dd:7f0d/128
PrivateKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
MTU = 1320
DNS = 10.128.0.1, fd7d:76ee:e68 f:a993::1, 1.1.1.1
[Peer]
PublicKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
PresharedKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Endpoint = 185.189.112.21:1637
AllowedIPs = 0.0.0.0/0
PersistentKeepalive = 15
After starting the tunnel with this configuration I lose access from VLAN47 to LXC (10.49.10.14)
I changed AllowedIPs to
AllowedIPs = 0.0.0.0/5, 8.0.0.0/7, 10.0.0.0/11, 10.32.0.0/13, 10.40.0.0/14, 10.44.0.0/15, 10.46.0.0/16, 10.47.0.0/24, 10.47.2.0/23, 10.47.4.0/22, 10.47.8.0/21, 10.47.16.0/20, 10.47.32.0/19, 10.47.64.0/18, 10.47.128.0/17, 10.48.0.0/12, 10.64.0.0/10, 10.128.0.0/9, 11.0.0.0/8, 12.0.0.0/6, 16.0.0.0/4, 32.0.0.0/3, 64.0.0.0/2, 128.0.0.0/1
Unfortunately, after this change I have access to LXC from vlan47, but this LXC has no internet. Ping 1.1.1.1 ping google.com does not respond
How do I change this config? Edited ... by osalj
This looks incorrect because in "AllowedIPs" you have to enter the ranges that you want inside the VPN. So, you are routing in the VPN even parts of the 10.0.0.0/8 subnet that you should not, if we understood correctly. Please try again with a subnet calculator and also compare with the following post:
https://airvpn.org/forums/topic/55801-wireguard-access-local-network/?do=findComment&comment=217458
