Friction7090
Eddie's window spawns blank
Greetings.
I've been having an issue with eddie for a while now, I tried using the cli version but I can't get it to do the same things I could with the gui, skill issue I'm sure.
When the window spawns it seems to be transparent, when I move it it's like moving a photograph, it keeps showing the things that were behind it the moment it spawned.
I'm on artix (arch linux fork) and I haven't been able to figure out what's wrong, I tried uninstalling and reinstalling too, no luck.
. 2024.10.31 17:59:13 - Eddie version: 2.24.2 / linux_x64, System: Linux, Name: Artix Linux, Version: Linux den 6.11.3-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Thu, 17 Oct 2024 12:46:36 +0000 x86_64 GNU/Linux, Framework: 6.8.0.96 (tarball Wed Jan 15 10:20:48 UTC 2020); Framework: v4.0.30319
. 2024.10.31 17:59:13 - Command line arguments (1): path.resources="/usr/share/eddie-ui"
. 2024.10.31 17:59:13 - Raise system privileges
Enable eddie-elevated.service failed
. 2024.10.31 17:59:17 - Collect network information
. 2024.10.31 17:59:18 - Reading options from /home/user/.config/eddie/default.profile
. 2024.10.31 17:59:18 - OpenVPN - Version: 2.6.12 - OpenSSL 3.4.0 22 Oct 2024, LZO 2.10 (/usr/bin/openvpn)
. 2024.10.31 17:59:18 - SSH - Version: OpenSSH_9.9p1, OpenSSL 3.4.0 22 Oct 2024 (/usr/bin/ssh)
I 2024.10.31 17:59:18 - SSL - Not available
I 2024.10.31 17:59:20 - Ready
. 2024.10.31 17:59:21 - Collect information about AirVPN completed
Here you go, thank you for your time, it's appreciated.
Admittedly, reading the output I did find something missing in gtk but even after installing it I have the same problem, but the output doesn't complain about the missing gtk stuff at least, so it's a bit cleaner.
Post some more info about your PC, please. With inxi, for example.
$ inxi -SGNI --za
System:
  Kernel: 6.11.3-zen1-1-zen arch: x86_64 bits: 64
  Desktop: Xfce v: 4.18.1 Distro: Artix Linux
Graphics:
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] driver: amdgpu v: kernel
  Device-2: MacroSilicon MiraBox Capture
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB
  Display: server: X.org v: 1.21.1.13 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon failed: fbdev,vesa dri: radeonsi gpu: amdgpu
    resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.5-arch1.1
    renderer: AMD Radeon RX 6600 (radeonsi navi23 LLVM 18.1.8 DRM 3.59
    6.11.3-zen1-1-zen)
Network:
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    driver: r8169
Info:
  Memory: total: 32 GiB available: 31.26 GiB used: 13.69 GiB (43.8%)
  Processes: 428 Uptime: 2h 1m Shell: Zsh inxi: 3.3.36
Any extra info I can provide?
I see. At this point I'd ask someone else with a Xfce desktop to test as well.
How did you install Eddie?
18 hours ago, Friction7090 said:
Through the AUR, I installed eddie-ui-git because the other option is out of date.
It's not out-of-date, it just tracks the stable releases of which the last was some time ago. But I understand your reasoning, I've got the -git version installed as well. :)
