When trying to launch minecraft on Prism Launcher, it says "the authentication servers are down. try again later."
I am sure that the authentication servers are not down because when joining with No VPN, it works perfectly fine. When turning the VPN on again it does not work. I have tried on both vanilla and modded minecraft and the same issue arises: I have attached a file showing my error message when trying to launch (because sometimes it doesnt even authenticate on launch). Other things I have tried is using wireguard/openvpn clients instead of Eddie, picking a different DNS, and whitelisting the routes shown here from a different post / finding their ips and whitelisting on wireguard as well: https://ibb.co/gmCPHgy
How do I check if I am actually whitelisting the IPs/the whitelisting works, and how do I check if I am still being blocked? I have no clue what I would do to fix this issue.
PrismLauncher-0.txt
