Amadore
ANSWERED Eddie UI not showing up after starting program
I have been using this program for years. No problems.
Today I do my usual. I click the icon to start Eddie. It shows it loading, etc. But then....nothing. Nothing at all. I click in Task Manager and it shows the UI running, but It is nowhere. It is not in my "Hidden Icons" either. Nowhere. So, I went and checked the site and updated to most recent version. I start the program, and still nothing after it loads. No UI. Nothing. It is still running in Task Manager, but not showing up on my desktop.
I recently disabled it showing up in Hidden Icons in the settings of Eddie. That was two weeks ago and has been working fine since. Could that be the issue? How do I get this to pop up now that I disabled it showing up in Hidden Icons? I fail to understand what is going on here. Nothing has changed on my PC either, no updates, etc. It worked just fine yesterday.
Is there a way I can find the settings of Eddie file and re-enable it showing up in Hidden Icons?
A pic to show that it is indeed running in Task Manager.
I am on Win 10 64.
Please help.
UPDATE: I completely uninstalled Eddie and reinstalled. It works fine now. I am going to assume there is a problem with disabling "Show in Tray" and "Minimize to tray" because there was never a problem all these years until I recently disabled (unchecked) those. I personally don't like the program starting to tray because it doesn't pop up, you have to go to tray and click it for it to pop up.
I also found this post (below). But, there was no way to click on the program in the tray because that option had been disabled. The only option for me was to uninstall. So, now I am stuck having the program go to hidden tray, which annoys me.
You can configure the tray to always show everything, or even always show specific items.
Also be advised that program settings are saved to your home directory. Deleting the default.profile file will reset Eddie settings. :)
I know that. As I said in my OP, after disabling "Show in Tray" and "Minimize to tray" that is when the problem started.
Please put this in another post so I can mark it as the solution.
There is a definite bug here, I am having the same issues. I tried the uninstall/reinstall approach with no positive outcome so I will manually delete the profile file and see if that helps.
If you still experience a similar problem after that, open your own thread. Do not hijack the threads of others.
