I can no longer access OneDrive with the vpn enabled.  I tested this on a computer with an without it on, on the same network.
I changed servers and it worked for about 10 minutes, then blocked again.
Anyone else having this issue?
This is what I get now:
The request is blocked.
Ref A: 9D46F388F65E41ECA947EEE54280BB9F Ref B: CO1EDGE2517 Ref 😄 2024-10-11T00:27:25Z
Thanks!
  Edited ... by Veep Peep
tried to get rid of smiley I did not put in
I encountered the same problem, and customer support said that Microsoft has blocked VPNs and there's no solution. It's really frustrating. I don't know whether I should switch to a different VPN or stop using OneDrive.
Edited ... by mingmingwu
It happened the same to me in the past with a different VPN provider, but after a couple of days it was working again. For sure it's VPN related, but no idea how or why it specifically happens.
Try not switching servers and stick to one while you're logged in to see if it gets resolved after a couple of days. Switching servers will make it worse.
I've been getting the "The request is blocked" message from many websites as well, using Edge for the browser. Just started happening a few days ago.
Almost surely AirVPN and Microsoft fighting; I turn off the VPN and it works fine.
Seems like there isn't a fix for it; maybe it'll work itself out someday.
