moderns 0 Posted ... Hi, Greetings! When I try to connect to login and connect to any of servers, I get message "failed to start" I am really beginner and I need your hints to forward traffic to my web server port which is 80, I generated some ports in my account but when connecting my server to my router, I cannot see the port using the tool: www.canyouseeme.org Please advise. Thanks. Quote Share this post Link to post
Staff 10386 Posted ... Hi,Greetings!When I try to connect to login and connect to any of servers, I get message "failed to start"Hello!Can you please send us the client logs?I am really beginner and I need your hints to forward traffic to my web server port which is 80, I generated some ports in my account but when connecting my server to my router, I cannot see the port using the tool: www.canyouseeme.orgAfter you have solved the previous problem:- forward a TCP port on our system (menu "Member Area"->"Forwarded ports")- remap that port to local port 80- reach your web server on http://<Air server exit-IP address>:<remotely forwarded port>Alternatively:- forward a TCP port on our system- configure your web server to listen to that port- reach your web server on http://<Air server exit-IP address>:<remotely forwarded port>Kind regards Quote Share this post Link to post
