abc_1312
Hot-spot Device VPN issue's
Hello dear community...
I have a problem.
Running the VPN on my main-device the Hot-spot connected second device don't run true the VPN .
Sourcing the ip-location the second device shows up ny real VPN .
Can someone help me ?
Thanks a lot
Edited ... by abc_1312
To clarify: The hotspot device is an Android device on which a VPN is running, and you want all clients connected to that hotspot go through the VPN, too?
There is an option for that starting from around Android 12 or so; it's found in the connection, hotspot or VPN settings and is called something like Allow clients to use VPN. If it's not there, you will need root because your manufacturer has not enabled this option in its Android distribution.
