FPyro
Very strange logs and no connection!
Hey!
Although the Client confirms the connection, I'm still NOT connected!
Here are the logs:
16.12.2012 - 23:01 AirVPN client version: 1,7
16.12.2012 - 23:01 Reading options from C:\Users\Pyro\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
16.12.2012 - 23:01 OpenVPN bundle version: OpenVPN 2.2.2
16.12.2012 - 23:01 OpenVPN current version: OpenVPN 2.3_rc1
16.12.2012 - 23:01 Login...
16.12.2012 - 23:01 Login success.
16.12.2012 - 23:02 Contacting service...
16.12.2012 - 23:02 Connecting...
16.12.2012 - 23:02 OpenVPN 2.3_rc1 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Nov 6 2012
16.12.2012 - 23:02 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
16.12.2012 - 23:02 Socket Buffers: R=[8192->8192] S=[8192->8192]
16.12.2012 - 23:02 UDPv4 link local: [undef]
16.12.2012 - 23:02 UDPv4 link remote: [AF_INET]95.211.149.200:443
16.12.2012 - 23:02 TLS: Initial packet from [AF_INET]95.211.149.200:443, sid=5474cedd 8d2c13f3
16.12.2012 - 23:02 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
16.12.2012 - 23:02 VERIFY OK: nsCertType=SERVER
16.12.2012 - 23:02 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
16.12.2012 - 23:02 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
16.12.2012 - 23:02 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
16.12.2012 - 23:02 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
16.12.2012 - 23:02 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
16.12.2012 - 23:02 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
16.12.2012 - 23:02 [server] Peer Connection Initiated with [AF_INET]95.211.149.200:443
16.12.2012 - 23:02 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
16.12.2012 - 23:02 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.3.230 10.4.3.229'
16.12.2012 - 23:02 OPTIONS IMPORT: timers and/or timeouts modified
16.12.2012 - 23:02 OPTIONS IMPORT: LZO parms modified
16.12.2012 - 23:02 OPTIONS IMPORT: --ifconfig/up options modified
16.12.2012 - 23:02 OPTIONS IMPORT: route options modified
16.12.2012 - 23:02 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
16.12.2012 - 23:02 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
16.12.2012 - 23:02 open_tun, tt->ipv6=0
16.12.2012 - 23:02 TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{BD411231-67D0-4B3D-A77A-33924C6858CE}.tap
16.12.2012 - 23:02 TAP-Windows Driver Version 9.9
16.12.2012 - 23:02 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.230/255.255.255.252 on interface {BD411231-67D0-4B3D-A77A-33924C6858CE} [DHCP-serv: 10.4.3.229, lease-time: 31536000]
16.12.2012 - 23:02 Successful ARP Flush on interface [47] {BD411231-67D0-4B3D-A77A-33924C6858CE}
16.12.2012 - 23:02 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
16.12.2012 - 23:02 Route: Waiting for TUN/TAP interface to come up...
16.12.2012 - 23:03 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
16.12.2012 - 23:03 Route: Waiting for TUN/TAP interface to come up...
16.12.2012 - 23:03 C:\Windows\system32\route.exe ADD 95.211.149.200 MASK 255.255.255.255 192.168.178.1
16.12.2012 - 23:03 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
16.12.2012 - 23:03 Route addition via IPAPI succeeded [adaptive]
16.12.2012 - 23:03 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.229
16.12.2012 - 23:03 Warning: route gateway is not reachable on any active network adapters: 10.4.3.229
16.12.2012 - 23:03 Route addition via IPAPI failed [adaptive]
16.12.2012 - 23:03 Route addition fallback to route.exe
16.12.2012 - 23:03 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
16.12.2012 - 23:03 OK!
16.12.2012 - 23:03 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.229
16.12.2012 - 23:03 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.229
16.12.2012 - 23:03 SYSTEM ROUTING TABLE
16.12.2012 - 23:03 78.1 p=0 i=10 t=4 pr=3 a=29155 h=0 m=10/0/0/0/0
16.12.2012 - 23:03 229 p=0 i=10 t=4 pr=3 a=0 h=0 m=11/0/0/0/0
16.12.2012 - 23:03 10.4.3.229 p=0 i=10 t=4 pr=3 a=0 h=0 m=11/0/0/0/0
16.12.2012 - 23:03 2 10.4.0.106 p=0 i=47 t=3 pr=3 a=1577 h=0 m=286/0/0/0/0
16.12.2012 - 23:03 5 10.4.0.106 p=0 i=47 t=3 pr=3 a=1577 h=0 m=286/0/0/0/0
16.12.2012 - 23:03 5.255 192.168.178.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
16.12.2012 - 23:03 .0.1 p=0 i=1 t=3 pr=3 a=38890 h=0 m=306/0/0/0/0
16.12.2012 - 23:03 127.0.0.1 p=0 i=1 t=3 pr=3 a=38890 h=0 m=306/0/0/0/0
16.12.2012 - 23:03 55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=38890 h=0 m=306/0/0/0/0
16.12.2012 - 23:03 3.229 p=0 i=10 t=4 pr=3 a=0 h=0 m=11/0/0/0/0
16.12.2012 - 23:03 .0 192.168.178.22 p=0 i=10 t=3 pr=3 a=29155 h=0 m=266/0/0/0/0
16.12.2012 - 23:03 5.255 192.168.178.22 p=0 i=10 t=3 pr=3 a=29155 h=0 m=266/0/0/0/0
16.12.2012 - 23:03 55.255 192.168.178.22 p=0 i=10 t=3 pr=3 a=29155 h=0 m=266/0/0/0/0
16.12.2012 - 23:03 0.106 p=0 i=47 t=3 pr=3 a=38873 h=0 m=286/0/0/0/0
16.12.2012 - 23:03 68.178.22 p=0 i=10 t=3 pr=3 a=38873 h=0 m=266/0/0/0/0
16.12.2012 - 23:03 55.255 10.4.0.106 p=0 i=47 t=3 pr=3 a=38873 h=0 m=286/0/0/0/0
16.12.2012 - 23:03 55.255 192.168.178.22 p=0 i=10 t=3 pr=3 a=38873 h=0 m=266/0/0/0/0
16.12.2012 - 23:03 SYSTEM ADAPTER LIST
16.12.2012 - 23:03 TAP-Windows Adapter V9 #2
16.12.2012 - 23:03 Index = 47
16.12.2012 - 23:03 B3D-A77A-33924C6858CE}
16.12.2012 - 23:03 .255.252
16.12.2012 - 23:03 MAC = 00:ff:bd:41:12:31
16.12.2012 - 23:03 55.255.255
16.12.2012 - 23:03 255.255.255.255
16.12.2012 - 23:03 un Dec 16 22:37:00 2012
16.12.2012 - 23:03 on Dec 16 22:37:00 2013
16.12.2012 - 23:03 .255.255.255
16.12.2012 - 23:03 -E Gigabit Ethernet Controller #2
16.12.2012 - 23:03 Index = 11
16.12.2012 - 23:03 43C-8034-F44E60E0F662}
16.12.2012 - 23:03 IP = 0.0.0.0/0.0.0.0
16.12.2012 - 23:03 MAC = bc:ae:c5:16:48:1c
16.12.2012 - 23:03 DHCP SERV =
16.12.2012 - 23:03 un Dec 16 23:03:17 2012
16.12.2012 - 23:03 DNS SERV =
16.12.2012 - 23:03 Index = 10
16.12.2012 - 23:03 85F-A573-FBC715657EDD}
16.12.2012 - 23:03 .255.255.0
16.12.2012 - 23:03 MAC = 00:10:0b:d2:0b:a8
16.12.2012 - 23:03 /255.255.255.255
16.12.2012 - 23:03 .1/255.255.255.255
16.12.2012 - 23:03 un Dec 16 15:10:56 2012
16.12.2012 - 23:03 ed Dec 26 15:10:56 2012
16.12.2012 - 23:03 Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
16.12.2012 - 23:03 Starting Management Interface...
16.12.2012 - 23:03 Checking...
16.12.2012 - 23:03 Retrieve statistics...
16.12.2012 - 23:03 Connected.
Thanks in advance
The tun/tap network adapter does not come up. Assuming that it is enabled (please see https://airvpn.org/index.php?option=com_kunena&func=view&catid=2&id=6247&Itemid=142#6248), please to try to remove and then re-install a TAP-Win32 Adapter (menu "Start"->"All Programs"->"OpenVPN"->"Utilities").
If the problem persists, try a reboot. If the problem is still there after a reboot, there might be a problem with the driver, please try to uninstall completely OpenVPN and re-install it, making sure to authorize the installer to install all the drivers.
It's working again , but I'm not sure what exactly I did that solved it. However, I'm also running the newsing RC1 of 2.3 OpenVPN :dry:
Thank you!
It's working again :) , but I'm not sure what exactly I did that solved it. However, I'm also running the newsing RC1 of 2.3 OpenVPN :dry:
Thank you!
We're glad to know that the problem is solved. If OpenVPN is suddenly working again without any change in your system, it's a reported (but unsolved), apparently random Windows bug we have seen on XP, Vista and 7. Usually the issue is solved with a reboot, sometimes (but not always) an "ipconfig /renew" is effective.
