thevesba123
ANSWERED What Network Interface to Bind to in qbittorrent?
My Apologies for making this post After I Believe I have Already Solved this issue, But I need clarification.
Torrenting doesn't work when I Set the network interface to "Eddie", And By manually testing All of them I deduced that Local Area Connection 2 doesn't leak my IP At All, would this Be the correct interface to Use?
Thanks in Advance from the real real kuku vesba.
@thevesba123
Please bind qBittorrent to the VPN interface. You can determine its name through Eddie log (click "Log" tab on Eddie's main window) or from Windows' Control Panel, or from the command prompt (type "ipconfig /all" to list all the interfaces). If in doubt please send us a system report generated by Eddie while a VPN connection is active. Please make sure to start qBittorrent only after the VPN connection has been established successfully.
From your description, your setup is already correct.
