zurahthustra 0 Posted ... I am trying to set up portforwarding to handle incoming bittorent request. But I continually get the error message "Already reserved by another user.". This is on Serpentis and I tried a number of different combinations. Quote Share this post Link to post
Staff 10433 Posted ... I am trying to set up portforwarding to handle incoming bittorent request. But I continually get the error message "Already reserved by another user.". This is on Serpentis and I tried a number of different combinations.Hello!For a bittorrent client, just let the system pick for you a free port. Do not remap it to a local port. Leave it to "TCP & UDP". Finally, set the same port number as the listening port in your torrent client.Kind regards Quote Share this post Link to post
mowax 0 Posted ... Hi, I have followed what you have said and let the system connect to a port, and then when I put it into the utorrent program it still shows as port not open, on the web site am I to wait until it shows a green light as when hovering over it it says waiting for a "checking" Quote Share this post Link to post
mowax 0 Posted ... here is the message. Not reachable on server IP over the external port xxxxx, tcp protocol. Error : 111 - Connection refused Quote Share this post Link to post
Staff 10433 Posted ... here is the message. Not reachable on server IP over the external port xxxxx, tcp protocol. Error : 111 - Connection refusedHello!Please make sure that your torrent client is running and listening to the correct port while the check is performed. When you order a port check to the system, please wait for about 30 seconds then click "Refresh".Kind regards Quote Share this post Link to post
mowax 0 Posted ... Thanks for the reply. yeah I have utorrent open and configured to see/use port 32991, That's the port that the server gave me. ??? Thanks Quote Share this post Link to post
mowax 0 Posted ... Ho sorted, it was a setting in Tomato, it was the following that I disabled and the port has opened in utorrent.... Thanks again. (when enabled, UPnP clients are allowed to add mappings only to their IP) Quote Share this post Link to post
