kajika
ANSWERED Wrong location using Japan UDP
Hello, this week the japan OpenVPN configuration is showing as Netherland. I haven't change anything and always use the same configuration (for months). I tried to re-generate the configuration but everything website (AirVPN too) is detecting me as in the Netherland instead of Japan.
Here's the beginning of the configuration file:
# Air VPN | https://airvpn.org | Monday 2nd of September 2024 [...]
# OpenVPN Client Configuration
# AirVPN_Japan_UDP-443-Entry3
client
dev tun
remote jp3.vpn.airdns.org 443
@kajika
That's because all of the Japan servers suffer of low packet loss. They are all in 'yellow' state and therefore the FQDN jp3.vpn.airdns.org does not resolve anymore into some Japan server entry IP address. While we're working to solve this issue, please consider to force the connection to some specific Japan server with a specific configuration file. Performance will not be optimal due to moderate packet loss, but the datacenter is working to solve the problem. The same is happening in Singapore.
