Not connected, Your IP: 216.73.216.20
TCP/IP
How does AirVPN perform when downloading large data amounts?
After going through half of the forum, I can say this VPN seems to be worth it. I’ve used different services before, and I often had issues with either speed or access. Can anyone share how well this VPN performs when downloading large amounts of data? 😄
Edited ... by TCP/IP
The current Top Users are at 116, 104 and 88 TB of data since May, May and July, respectively. One particular case, without mentioning names, is currently downloading 57 TB of data at 458 Mbit/s. I think you will be quite fine, if you can manage to get a good line in Berlin, that is. :P And with good line I mean Fiber. Not sure if there is Fiber in Berlin already.
As long as your counterparty is not throttling AirVPN's connections by IP on purpose, and as long as your hardware has enough processing power, you can leverage a Wireguard connection to AirVPN to get a connection that operates at linespeed.
