So everything worked fine but now i'm facing this wintun issue. Log:
. 2024.08.23 10:40:56 - Eddie version: 2.24.2 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: 10.0.22631.0, Framework: v4.0.30319
. 2024.08.23 10:40:56 - Command line arguments (1): path="home"
. 2024.08.23 10:40:57 - Collect network information
. 2024.08.23 10:40:57 - Reading options from C:\Users\imgod\AppData\Local\Eddie\default.profile
. 2024.08.23 10:40:58 - OpenVPN - Version: 2.6.9 - OpenSSL 3.2.0 23 Nov 2023, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.08.23 10:40:58 - SSH - Version: OpenSSH_for_Windows_8.6p1, LibreSSL 3.4.3 (C:\Windows\System32\OpenSSH\\ssh.exe)
. 2024.08.23 10:40:58 - SSL - Version: 5.69 (C:\Program Files\AirVPN\stunnel.exe)
I 2024.08.23 10:40:58 - Ready
. 2024.08.23 10:40:59 - Collect information about AirVPN completed
! 2024.08.23 10:41:05 - Logged out.
I 2024.08.23 10:41:11 - Checking login ...
! 2024.08.23 10:41:11 - Logged in.
I 2024.08.23 10:41:30 - Session starting.
. 2024.08.23 10:41:30 - Activation of Network Lock - Windows Filtering Platform
I 2024.08.23 10:41:30 - Checking authorization ...
. 2024.08.23 10:41:31 - Collect network information
E 2024.08.23 10:41:42 - Exception: wintun.dll WintunCreateAdapter fail, pool:'Eddie', name:'eddie', nr:N, error : 'The system cannot find the file specified.'
I 2024.08.23 10:41:45 - Cancel requested.
. 2024.08.23 10:41:45 - Deactivation of Network Lock
! 2024.08.23 10:41:45 - Session terminated.
I uninstalled Eddie, installed it again, uninstalled, installed experimental version and nothing works. I changed VPN interface name in Networking tab to Eddie and it didn't help too. I removed all TAP adapters and it didn't help. I searched the forums but couldn't find the solution.
Please provide a system report, which contains info on your Wireguard driver and other relevant things, too..
Some people solved it by installing the vanilla OpenVPN client and let it install a WinTun adapter. Remove the eddie name from the settings after installation, though.
Others simply tried Wireguard instead.
