shane_b
Block traffic when VPN disconnects error with BT
Hi
I managed to follow the tutorial posted here sometime ago and successfully set up a connection using waterproof and viscosity. However my girlfriend has just changed to BT internet and airport (osx) now doesn't make an internet connection and self defines an IP address. The default gateway for bt is 192.168.254 and I usually auto connect to 192.168.1.88 so I don't understand where I am going wrong
Here is what I have
sudo sysctl -w net.inet.ip.fw.enable=0
sudo sysctl -w net.inet.ip.forwarding=0
sudo ipfw flush
sudo ipfw delete set 31
sudo sysctl -w net.inet.ip.fw.enable=1
sudo sysctl -w net.inet.ip.fw.verbose=1
sudo sysctl -w net.inet.ip.fw.verbose_limit=5000
sudo ipfw add 01002 allow udp from 192.168.0.0/24 to 95.211.191.33 dst-port 443 keep-state
sudo ipfw add 01004 allow udp from 192.168.0.0/24 to 69.163.36.66 dst-port 443 keep-state
sudo ipfw add 01006 allow udp from 192.168.0.0/24 to 31.193.12.98 dst-port 443 keep-state
sudo ipfw add 01008 allow udp from 192.168.1.0/24 to 95.211.191.33 dst-port 443 keep-state
sudo ipfw add 01012 allow udp from 192.168.1.0/24 to 69.163.36.66 dst-port 443 keep-state
sudo ipfw add 01014 allow udp from 192.168.1.0/24 to 31.193.12.98 dst-port 443 keep-state
sudo ipfw add 02002 allow ip from 192.168.0.0/24 to 95.211.191.33 dst-port 443 keep-state
sudo ipfw add 02004 allow ip from 192.168.0.0/24 to 69.163.36.66 dst-port 443 keep-state
sudo ipfw add 02006 allow ip from 192.168.0.0/24 to 31.193.12.98 dst-port 443 keep-state
sudo ipfw add 02008 allow ip from 192.168.1.0/24 to 95.211.191.33 dst-port 443 keep-state
sudo ipfw add 02012 allow ip from 192.168.1.0/24 to 69.163.36.66 dst-port 443 keep-state
sudo ipfw add 02014 allow ip from 192.168.1.0/24 to 31.193.12.98 dst-port 443 keep-state
sudo ipfw add 03000 allow ip from 192.168.0.0/24 to 192.168.0.0/24 keep-state
sudo ipfw add 03002 allow ip from 192.168.1.0/24 to 192.168.1.0/24 keep-state
sudo ipfw add 04000 allow ip from 127.0.0.1 to any
sudo ipfw add 05000 allow ip from 10.0.0.0/8 to any
sudo ipfw add 05002 allow ip from any to 10.0.0.0/8
sudo ipfw add 65534 deny ip from any to any
