zaphod323
Entry IP rule for Comodo for all Air VPN servers
Hi, how do I determine the IP range so I can complete the following network zone for Air servers entry IPs? Also, is there some way to switch between UDP and TCP? I notice that I'm not getting any leaks now but my speed is about 1Mb/s when it's usually 25 Mb/s.
For your comfort, you might define a Network Zone (for example [Air servers entry IPs]) containing only the entry-IP addresses of our servers and then set two rules like
Allow TCP or UDP In/Out From In [Air servers entry IPs] To MAC Any Where Source Port Is Any And Destination Port Is Any
Allow TCP or UDP In/Out From MAC Any To In [Air servers entry IPs] Where Source Port Is Any And Destination Port Is Any
Please find the entry-IP addresses from the .ovpn configuration files or just ask us for them in private. We are reluctant to publish in the forum all the VPN servers entry-IP addresses.
