Not connected, Your IP: 216.73.216.210
Sokel
Got stuck on IPv4 stage and TCP connection stage, too
Hello, bought an subscirption recently and tried to connect
Firstly, got stuck with an IPv4 connection and tried to fix it using info on forums
Tried to connect via TCP protocol and got this:
. 2024.07.14 21:55:50 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Enterprise LTSC 2019, Version: Microsoft Windows NT 10.0.17763.0, Mono/.Net: v4.0.30319
. 2024.07.14 21:55:52 - Reading options from C:\Program Files\AirVPN\default.profile
. 2024.07.14 21:55:53 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.07.14 21:55:53 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.07.14 21:55:53 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2024.07.14 21:55:54 - Ready
. 2024.07.14 21:55:54 - Collect information about AirVPN completed
I 2024.07.14 21:56:45 - Session starting.
I 2024.07.14 21:56:45 - Checking authorization ...
. 2024.07.14 21:56:46 - Added new network interface "Eddie", Wintun version 0.12
. 2024.07.14 21:56:46 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.07.14 21:56:47 - Connecting to Ancha (Netherlands, Alblasserdam)
. 2024.07.14 21:56:47 - Routes, add 213.152.162.167/32 for interface "Hamachi (LogMeIn Hamachi Virtual Ethernet Adapter)".
. 2024.07.14 21:56:47 - Routes, add 213.152.162.167/32 for interface "Hamachi (LogMeIn Hamachi Virtual Ethernet Adapter)", already exists.
. 2024.07.14 21:56:47 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.07.14 21:56:47 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.07.14 21:56:47 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.07.14 21:56:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.07.14 21:56:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.07.14 21:56:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.07.14 21:56:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.07.14 21:56:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.167:443
. 2024.07.14 21:56:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.07.14 21:56:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.162.167:443 [nonblock]
Enterprise? Is this a work laptop?
Revert your settings. Then reboot Windows (not shutdown + startup), open Eddie and try a connection. Let it maybe loop once or twice, then:Don't just copy the logs if using Eddie.
