Not connected, Your IP: 216.73.216.36
zaphod323
[SOLVED] DNS leak other than Comodo
It won't let me browse to airvpn.org.
Here you're probably wrong, because you wrote your message while connected to the VPN.
My dos prompt stuff is attached.
It shows that you have connectivity inside the VPN but your computer can't resolve names. You can only browse to airvpn.org because it's in the hosts file and does not need DNS resolution. It is a DNS issue. Can you please try to change DNS on your physical interface and set 10.4.0.1 as primary (preferred) DNS IP address?
I attached the client logs in the previous message, if the client logs are the output from COmodo.
Please right-click on the Air dock icon when you're connected to the VPN, select "Logs", click "Copy to clipboard" and paste in a message.
12/5/2012 - 5:32 PM AirVPN client version: 1.7
12/5/2012 - 5:32 PM Reading options from C:\Users\madglee\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
12/5/2012 - 5:32 PM OpenVPN bundle version: OpenVPN 2.2.2
12/5/2012 - 5:32 PM OpenVPN current version: OpenVPN 2.2.2
12/5/2012 - 5:32 PM Ready.
12/5/2012 - 5:33 PM Login...
12/5/2012 - 5:33 PM Login success.
12/5/2012 - 5:33 PM Contacting service...
12/5/2012 - 5:33 PM Connecting...
12/5/2012 - 5:33 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
12/5/2012 - 5:33 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
12/5/2012 - 5:33 PM LZO compression initialized
12/5/2012 - 5:33 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
12/5/2012 - 5:33 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
12/5/2012 - 5:33 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
12/5/2012 - 5:33 PM Local Options hash (VER=V4): '22188c5b'
12/5/2012 - 5:33 PM Expected Remote Options hash (VER=V4): 'a8f55717'
12/5/2012 - 5:33 PM UDPv4 link local: [undef]
12/5/2012 - 5:33 PM UDPv4 link remote: 69.163.36.106:443
12/5/2012 - 5:33 PM TLS: Initial packet from 69.163.36.106:443, sid=4855cff8 f1d82094
12/5/2012 - 5:33 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
12/5/2012 - 5:33 PM VERIFY OK: nsCertType=SERVER
12/5/2012 - 5:33 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
12/5/2012 - 5:33 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/5/2012 - 5:33 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/5/2012 - 5:33 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/5/2012 - 5:33 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/5/2012 - 5:33 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
12/5/2012 - 5:33 PM [server] Peer Connection Initiated with 69.163.36.106:443
12/5/2012 - 5:33 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
12/5/2012 - 5:33 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.3.118 10.4.3.117'
12/5/2012 - 5:33 PM OPTIONS IMPORT: timers and/or timeouts modified
12/5/2012 - 5:33 PM OPTIONS IMPORT: LZO parms modified
12/5/2012 - 5:33 PM OPTIONS IMPORT: --ifconfig/up options modified
12/5/2012 - 5:33 PM OPTIONS IMPORT: route options modified
12/5/2012 - 5:33 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
12/5/2012 - 5:33 PM ROUTE default_gateway=192.168.1.1
12/5/2012 - 5:33 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{A4B902C7-C304-48AF-A43B-D012D4E536DE}.tap
12/5/2012 - 5:33 PM TAP-Win32 Driver Version 9.9
12/5/2012 - 5:33 PM TAP-Win32 MTU=1500
12/5/2012 - 5:33 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.3.118/255.255.255.252 on interface {A4B902C7-C304-48AF-A43B-D012D4E536DE} [DHCP-serv: 10.4.3.117, lease-time: 31536000]
12/5/2012 - 5:33 PM Successful ARP Flush on interface [16] {A4B902C7-C304-48AF-A43B-D012D4E536DE}
12/5/2012 - 5:33 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
12/5/2012 - 5:33 PM C:\WINDOWS\system32\route.exe ADD 69.163.36.106 MASK 255.255.255.255 192.168.1.1
12/5/2012 - 5:33 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
12/5/2012 - 5:33 PM Route addition via IPAPI succeeded [adaptive]
12/5/2012 - 5:33 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.117
12/5/2012 - 5:33 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
12/5/2012 - 5:33 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.117
12/5/2012 - 5:33 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.117
12/5/2012 - 5:33 PM Initialization Sequence Completed
12/5/2012 - 5:33 PM Starting Management Interface...
12/5/2012 - 5:33 PM Checking...
12/5/2012 - 5:33 PM Retrieve statistics...
12/5/2012 - 5:33 PM Connected.
12/5/2012 - 5:42 PM Disconnecting...
12/5/2012 - 5:42 PM SIGTERM received, sending exit notification to peer
12/5/2012 - 5:42 PM TCP/UDP: Closing socket
12/5/2012 - 5:42 PM Disconnected.
12/5/2012 - 5:42 PM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.3.117
12/5/2012 - 5:42 PM Route deletion via IPAPI succeeded [adaptive]
12/5/2012 - 5:42 PM C:\WINDOWS\system32\route.exe DELETE 69.163.36.106 MASK 255.255.255.255 192.168.1.1
12/5/2012 - 5:42 PM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.3.117
12/5/2012 - 5:42 PM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.3.117
12/5/2012 - 5:42 PM Closing TUN/TAP interface
12/5/2012 - 5:42 PM SIGTERM[hard,] received, process exiting
12/5/2012 - 5:42 PM Login...
12/5/2012 - 5:42 PM Login success.
12/5/2012 - 5:42 PM Contacting service...
12/5/2012 - 5:42 PM Connecting...
12/5/2012 - 5:42 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
12/5/2012 - 5:42 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
12/5/2012 - 5:42 PM LZO compression initialized
12/5/2012 - 5:42 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
12/5/2012 - 5:42 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
12/5/2012 - 5:42 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
12/5/2012 - 5:42 PM Local Options hash (VER=V4): '22188c5b'
12/5/2012 - 5:42 PM Expected Remote Options hash (VER=V4): 'a8f55717'
12/5/2012 - 5:42 PM UDPv4 link local: [undef]
12/5/2012 - 5:42 PM UDPv4 link remote: 69.163.36.106:443
12/5/2012 - 5:42 PM TLS: Initial packet from 69.163.36.106:443, sid=905d7e40 c41c889f
12/5/2012 - 5:42 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
12/5/2012 - 5:42 PM VERIFY OK: nsCertType=SERVER
12/5/2012 - 5:42 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
12/5/2012 - 5:42 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/5/2012 - 5:42 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/5/2012 - 5:42 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
12/5/2012 - 5:42 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
12/5/2012 - 5:42 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
12/5/2012 - 5:42 PM [server] Peer Connection Initiated with 69.163.36.106:443
12/5/2012 - 5:42 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
12/5/2012 - 5:42 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.3.118 10.4.3.117'
12/5/2012 - 5:42 PM OPTIONS IMPORT: timers and/or timeouts modified
12/5/2012 - 5:42 PM OPTIONS IMPORT: LZO parms modified
12/5/2012 - 5:42 PM OPTIONS IMPORT: --ifconfig/up options modified
12/5/2012 - 5:42 PM OPTIONS IMPORT: route options modified
12/5/2012 - 5:42 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
12/5/2012 - 5:42 PM ROUTE default_gateway=192.168.1.1
12/5/2012 - 5:42 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{A4B902C7-C304-48AF-A43B-D012D4E536DE}.tap
12/5/2012 - 5:42 PM TAP-Win32 Driver Version 9.9
12/5/2012 - 5:42 PM TAP-Win32 MTU=1500
12/5/2012 - 5:42 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.3.118/255.255.255.252 on interface {A4B902C7-C304-48AF-A43B-D012D4E536DE} [DHCP-serv: 10.4.3.117, lease-time: 31536000]
12/5/2012 - 5:42 PM Successful ARP Flush on interface [16] {A4B902C7-C304-48AF-A43B-D012D4E536DE}
12/5/2012 - 5:43 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
12/5/2012 - 5:43 PM C:\WINDOWS\system32\route.exe ADD 69.163.36.106 MASK 255.255.255.255 192.168.1.1
12/5/2012 - 5:43 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
12/5/2012 - 5:43 PM Route addition via IPAPI succeeded [adaptive]
12/5/2012 - 5:43 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.3.117
12/5/2012 - 5:43 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
12/5/2012 - 5:43 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.3.117
12/5/2012 - 5:43 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.3.117
12/5/2012 - 5:43 PM Initialization Sequence Completed
12/5/2012 - 5:43 PM Starting Management Interface...
12/5/2012 - 5:43 PM Checking...
12/5/2012 - 5:43 PM Retrieve statistics...
12/5/2012 - 5:43 PM Connected.
How do I change my physical adapter IP number? Sorry I'm not sure if you mean my router or my network card or how to do that.
Wait a sec..since I changed that preferred DNS I think it's working. The block rule is on and I'm on the VPN and I don't see leaks on DNSleaktest. I also can browse. I think.
Not sure how that DNS preferred server was 0.0.0.0 before. I think everything is working. The 3 IPs that show up on dnsleaktest.com are
in the range of 74.125.186.152 74.125.186.151 and 74.125.186.145 and I think those are from you guys, right?
Thank you so much for taking so much time to help me! This is truly excellent customer service and I really appreciate it.
Glad to know that the problem is solved. In dnsleaktest.com you correctly see only Google DNS, which is the last DNS queried by the Air servers.
Thank you!
One last thing: What are the entry IP addresses and/or rule I'd create for this network zone (as I may want to try some different servers to determine how fast my speeds are):
My speeds are currently like 1.2MB/s and they're usually about 25MB/s. Maybe this is because in my details I see all UDP and I notice you mention that if there's a speed problem, use TCP? I'm not sure how to set it so that when I connect it's through TCP. I'm trying to learn; sorry, just missing fundamental understanding of routing and network rules but I'm starting to get it.
For your comfort, you might define a Network Zone (for example [Air servers entry IPs]) containing only the entry-IP addresses of our servers and then set two rules like
Allow TCP or UDP In/Out From In [Air servers entry IPs] To MAC Any Where Source Port Is Any And Destination Port Is Any
Allow TCP or UDP In/Out From MAC Any To In [Air servers entry IPs] Where Source Port Is Any And Destination Port Is Any
Thanks again.
