puser 0 Posted ... Distributor ID: Debian Description: Debian GNU/Linux trixie/sid Quote penVPN 2.6.9 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO] library versions: OpenSSL 3.2.2-dev , LZO 2.10 DCO version: N/A Originally developed by James Yonan Copyright (C) 2002-2023 OpenVPN Inc <sales@openvpn.net> Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto_ofb_cfb=yes enable_dco=yes enable_dco_arg=yes enable_debug=yes enable_dependency_tracking=no enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_maintainer_mode=no enable_management=yes enable_option_checking=no enable_pam_dlopen=no enable_pedantic=no enable_pkcs11=yes enable_plugin_auth_pam=yes enable_plugin_down_root=yes enable_plugins=yes enable_port_share=yes enable_selinux=no enable_shared=yes enable_shared_with_static_runtimes=no enable_silent_rules=no enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=yes enable_unit_tests=no enable_werror=no enable_win32_dll=yes enable_wolfssl_options_h=yes enable_x509_alt_username=yes with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_openssl_engine=auto with_sysroot=no var 1 client dev tun remote 146.70.111.21 443 resolv-retry infinite nobind persist-key persist-tun auth-nocache verb 3 explicit-exit-notify 5 remote-cert-tls server data-ciphers AES-256-GCM:AES-192-GCM:AES-128-GCM data-ciphers-fallback AES-256-GCM disable-dco proto udp auth SHA512 2024-06-11 19:59:24 OpenVPN 2.6.9 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO] 2024-06-11 19:59:24 library versions: OpenSSL 3.2.2-dev , LZO 2.10 2024-06-11 19:59:24 DCO version: N/A 2024-06-11 19:59:24 TCP/UDP: Preserving recently used remote address: [AF_INET]146.70.111.21:443 2024-06-11 19:59:24 Socket Buffers: R=[212992->212992] S=[212992->212992] 2024-06-11 19:59:24 UDPv4 link local: (not bound) 2024-06-11 19:59:24 UDPv4 link remote: [AF_INET]146.70.111.21:443 2024-06-11 19:59:24 TLS: Initial packet from [AF_INET]146.70.111.21:443, sid=9ee8053b 1e07d4f3 2024-06-11 20:00:24 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 2024-06-11 20:00:24 TLS Error: TLS handshake failed 2024-06-11 20:00:24 SIGUSR1[soft,tls-error] received, process restarting 2024-06-11 20:00:24 Restart pause, 1 second(s) var 2 client dev tun remote nl3.vpn.airdns.org 443 resolv-retry infinite nobind persist-key persist-tun auth-nocache verb 3 explicit-exit-notify 5 remote-cert-tls server data-ciphers AES-256-GCM:AES-192-GCM:AES-128-GCM data-ciphers-fallback AES-256-GCM disable-dco proto udp auth SHA512 2024-06-11 20:01:31 OpenVPN 2.6.9 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO] 2024-06-11 20:01:31 library versions: OpenSSL 3.2.2-dev , LZO 2.10 2024-06-11 20:01:31 DCO version: N/A 2024-06-11 20:01:32 TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.26:443 2024-06-11 20:01:32 Socket Buffers: R=[212992->212992] S=[212992->212992] 2024-06-11 20:01:32 UDPv4 link local: (not bound) 2024-06-11 20:01:32 UDPv4 link remote: [AF_INET]213.152.186.26:443 2024-06-11 20:01:32 TLS: Initial packet from [AF_INET]213.152.186.26:443, sid=1ea938db 3b2b6b6b 2024-06-11 20:02:32 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 2024-06-11 20:02:32 TLS Error: TLS handshake failed 2024-06-11 20:02:32 SIGUSR1[soft,tls-error] received, process restarting 2024-06-11 20:02:32 Restart pause, 1 second(s) Share this post Link to post
Air4141841 30 Posted ... have you regenerated your keys and verified the TLS key is correct? Share this post Link to post
go558a83nk 383 Posted ... This happens for me almost all the time and it's my ISP causing it. Try TCP tls-crypt and see if that has the same problem. Share this post Link to post
gekoch 0 Posted ... On 6/15/2024 at 4:39 PM, go558a83nk said: This happens for me almost all the time and it's my ISP causing it. Try TCP tls-crypt and see if that has the same problem. Thx I have the same problems since a few hours. Where do I need to set ths "tls -crypt" Share this post Link to post
Tech Jedi Alex 1524 Posted ... On 12/13/2024 at 10:40 AM, gekoch said: Thx I have the same problems since a few hours. Where do I need to set ths "tls -crypt" Open your own thread, please, giving as much info as you can about the problem you're having. You may link to this thread, too. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
