Mr.CivsteR
ANSWERED Config Generator and DuckDuckGo for iOS Issues
When using DuckDuckGo browser for iOS to generate a configuration, the downloaded file seems to be the config generator page in html but with .ovpn extension. Importing this file to OpenVPN for iOS will fail.
Edited ... by Rotciv
Hey, I remember this.
Along with 2-3 other mentions across the forums I can't find right now. Still not fixed, I see.
It is possible that it's something caused by an ancient bug affecting various browsers and reported (on Android too) about 15 years ago: https://issuetracker.google.com/issues/36906622 or something related to mime types. In some rare cases this issue has been correlated to download managers as well.
In iOS, for this specific task please use Safari, Chrome or Opera (without download manager extensions, if necessary), which are not affected by that (or similar) bug and can download files from the CG properly.
If you decide to try and run WireGuard, you may also avoid downloading a file. You can consider to use a computer and shoot (on the computer monitor) the QR code rendered by our Configuration Generator to import the WireGuard configuration file into your iOS device.
