Theetjuh
ANSWERED OpenWRT Wireguard IPv6 incoming
I have created an OpenWRT router on my Proxmox server, the wireguard connection is working.
I can use ping and ping6, traceroute and traceroute6 all works well, also from the LAN.
Except … incoming port forwarding on IPv6 keeps failing, IPv4 is working perfectly.
Any got a pointer?
I am not an expert with OpenWRT, but got some basic knowledge.
Nevermind, I just found out it is because Deluge isn’t dualstack compatible, when I force it to IPv6 only, that works.
