petes58956jfd 2 Posted ... I am doing Pfsense OVPN G2G to servers Xuange & Sirrah but whenever downloading releases from github.com I get a net total of 90KBps (1 or more downloads). If I use Proxysite.com I at least get 450Kbps. Anyone have any better workarounds or ....? Quote Share this post Link to post
Staff 10417 Posted ... On 5/3/2024 at 5:05 PM, petes58956jfd said: whenever downloading releases from github.com I get a net total of 90KBps (1 or more downloads). Hello! We can't reproduce at the moment... Does this problem occur only with github.com? What performance do you get with downloads from other sources? And with an HTTP based speed test? Which server(s) do you connect to? Kind regards Quote Share this post Link to post
petes58956jfd 2 Posted ... Github is most of my browsing, but I do know it has happened on other sites too. ATM (All inside the tunnel): I am downloading/installing bitdefender and I am getting 450KB/s for the last 25 minutes. I am trying nvidia driver download now and it tops at ~620KB/s (not many MB/s). Speedtest.net: with "Single Connection" I get 8.2Mbps by 2.20Mbps. If I do Multi-Connections it is much better: 77.90Mbps by 8.67Mbps Speed.Couldflare.com: (No settings to change) Eventually gives 54Mbps by 4.97Mbps (attached). Also, Torrent downloading can get to higher speeds in many MB/s (expecting the multi connections is reason also). Internet Speed Test - Measure Network Performance Cloudflare.pdf Quote Share this post Link to post
Staff 10417 Posted ... 9 hours ago, petes58956jfd said: If I do Multi-Connections it is much better: 77.90Mbps by 8.67Mbps Hello! Please try to switch to WireGuard and test again with various MTU (ranging from 1280 to 1420 bytes). The option in WireGuard's configuration file to change VPN interface MTU is MTU = n where n is in bytes. The directive must be entered in the [Interface] section. Kind regards Quote Share this post Link to post
