i-t-s-m-e 1 Posted ... Is it possible to install multiple wireguard connections from my pfsense to airvpn? If i get the config from airvpn i get every time the same interface address 10.187.61.xxx, i cannot setup multiple wireguard instances on pfsense with the same interface address. I want to remove my 4 openvpn's and change them to wireguard. Quote Share this post Link to post
Staff 10417 Posted ... 5 hours ago, nan0tEch said: If i get the config from airvpn i get every time the same interface address 10.187.61.xxx, i cannot setup multiple wireguard instances on pfsense with the same interface address. Hello! WireGuard can't assign addresses dynamically so each address is linked to a single key. With multiple keys you will have multiple addresses. Please generate different keys in your AirVPN account "Client Area" > "Devices" pane and use each key for a unique connection. Instructions are available here: https://airvpn.org/forums/topic/26209-how-to-manage-client-certificatekey-pairs/ Kind regards Quote Share this post Link to post
i-t-s-m-e 1 Posted ... thanks for the info, didn't know that the devices gave me different keys. Quote Share this post Link to post
