acute-playpen-downy-qatar
ANSWERED Checking DNS fails on macOS with WireGuard
I'm able to connect fine using OpenVPN. When I try to connect with WireGuard (any profile), Eddie fails at "Checking DNS." What could be going on?
Eddie System/Environment Report - 4/22/2024 - 6:13 PM UTC
Eddie version: 2.21.8
Eddie OS build: macos_x64
Eddie architecture: x64
OS type: MacOS
OS name: macOS 14.4.1
OS version: 14.4.1 (Build 23E224)
OS architecture: x64
Mono /.Net Framework: v4.0.30319
OpenVPN: 2.5.5 - OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
Hummingbird: 3.3.2 - Hummingbird - AirVPN OpenVPN 3 Client 1.2.0 - 22 March 2022 (/Applications/Eddie.app/Contents/MacOS/hummingbird)
WireGuard: 1.0.20210315
SSH: OpenSSH_9.6p1, LibreSSL 3.3.6 (/usr/bin/ssh)
SSL: Initializing (/Applications/Eddie.app/Contents/MacOS/stunnel)
Profile path: /Users/redacted/.config/eddie/default.profile
Data path: /Users/redacted/.config/eddie
Application path: /Applications/Eddie.app/Contents/MacOS
Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie
Command line arguments: (0 args)
Network Lock Active: No
Connected to VPN: No
OS support IPv4: Yes
OS support IPv6: Yes
Detected DNS: 10.128.0.1, fd7d:76ee:e68f:a993::1
Test DNS IPv4: Failed
Test DNS IPv6: Failed
Test Ping IPv4: 113 ms
Test Ping IPv6: 115 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
key: (omissis)
servers.allowlist: bd13e366d023f96e7b42afb6d3b1b774e22e2499f48e74333e1d48dd3845ea77
mode.type: wireguard
mode.protocol: UDP
mode.port: 51820
mode.alt: 2
Logs:
. 2024.04.22 14:03:42 - Eddie version: 2.21.8 / macos_x64, System: MacOS, Name: macOS 14.4.1, Version: 14.4.1 (Build 23E224), Mono/.Net: v4.0.30319
. 2024.04.22 14:03:42 - Raise system privileges
. 2024.04.22 14:03:48 - Profile options not found, using defaults.
. 2024.04.22 14:03:50 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2024.04.22 14:03:50 - SSH - Version: OpenSSH_9.6p1, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2024.04.22 14:03:50 - SSL - Version: Initializing (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2024.04.22 14:03:50 - Ready
. 2024.04.22 14:03:52 - Collect information about AirVPN completed
I 2024.04.22 14:05:25 - Checking login ...
! 2024.04.22 14:05:26 - Logged in.
I 2024.04.22 14:05:43 - Session starting.
I 2024.04.22 14:05:43 - Checking authorization ...
! 2024.04.22 14:05:44 - Connecting to Wurren (Canada, Toronto, Ontario)
. 2024.04.22 14:05:44 - Routes, add 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:05:44 - Routes, add 199.189.27.125/32 for interface "en0", already exists.
. 2024.04.22 14:05:44 - OpenVPN > OpenVPN 2.5.5 arm-apple-darwin21.3.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2024.04.22 14:05:44 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2024.04.22 14:05:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.22 14:05:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.22 14:05:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.22 14:05:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.22 14:05:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.189.27.125:443
. 2024.04.22 14:05:44 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2024.04.22 14:05:44 - OpenVPN > UDP link local: (not bound)
. 2024.04.22 14:05:44 - OpenVPN > UDP link remote: [AF_INET]199.189.27.125:443
. 2024.04.22 14:05:44 - OpenVPN > TLS: Initial packet from [AF_INET]199.189.27.125:443, sid=d93a641a 0e1b0a01
. 2024.04.22 14:05:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2024.04.22 14:05:44 - OpenVPN > VERIFY KU OK
. 2024.04.22 14:05:44 - OpenVPN > Validating certificate extended key usage
. 2024.04.22 14:05:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2024.04.22 14:05:44 - OpenVPN > VERIFY EKU OK
. 2024.04.22 14:05:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wurren, emailAddress=info@airvpn.org
. 2024.04.22 14:05:46 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2024.04.22 14:05:46 - OpenVPN > [Wurren] Peer Connection Initiated with [AF_INET]199.189.27.125:443
. 2024.04.22 14:05:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.66.22.1,dhcp-option DNS6 fde6:7a:7d20:3e16::1,tun-ipv6,route-gateway 10.66.22.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:3e16::1035/64 fde6:7a:7d20:3e16::1,ifconfig 10.66.22.55 255.255.255.0,peer-id 15,cipher AES-256-GCM'
. 2024.04.22 14:05:46 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2024.04.22 14:05:46 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.66.22.1'
. 2024.04.22 14:05:46 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:3e16::1'
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2024.04.22 14:05:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2024.04.22 14:05:46 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2024.04.22 14:05:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2024.04.22 14:05:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2024.04.22 14:05:46 - OpenVPN > Opened utun device utun8
. 2024.04.22 14:05:46 - OpenVPN > /sbin/ifconfig utun8 delete
. 2024.04.22 14:05:47 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2024.04.22 14:05:47 - OpenVPN > Error: route: writing to routing socket: File exists
. 2024.04.22 14:05:47 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2024.04.22 14:05:47 - OpenVPN > /sbin/ifconfig utun8 10.66.22.55 10.66.22.55 netmask 255.255.255.0 mtu 1500 up
. 2024.04.22 14:05:47 - OpenVPN > /sbin/route add -net 10.66.22.0 10.66.22.55 255.255.255.0
. 2024.04.22 14:05:47 - OpenVPN > add net 10.66.22.0: gateway 10.66.22.55
. 2024.04.22 14:05:47 - OpenVPN > /sbin/ifconfig utun8 inet6 fde6:7a:7d20:3e16::1035/64 mtu 1500 up
. 2024.04.22 14:05:47 - OpenVPN > add_route_ipv6(fde6:7a:7d20:3e16::/64 -> fde6:7a:7d20:3e16::1035 metric 0) dev utun8
. 2024.04.22 14:05:47 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:3e16:: -prefixlen 64 -iface utun8
. 2024.04.22 14:05:47 - OpenVPN > add net fde6:7a:7d20:3e16::: gateway utun8: File exists
. 2024.04.22 14:05:47 - OpenVPN > Initialization Sequence Completed
. 2024.04.22 14:05:47 - DNS of a network adapter forced (ThinkPad TBT 3 Dock, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:05:47 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:05:47 - DNS of a network adapter forced (HERO10 Black, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:05:47 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:05:47 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:05:47 - DNS of a network adapter forced (Tailscale Tunnel, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:05:47 - Routes, add 0.0.0.0/1 for interface "utun8".
. 2024.04.22 14:05:47 - Routes, add 128.0.0.0/1 for interface "utun8".
. 2024.04.22 14:05:47 - Routes, add ::/1 for interface "utun8".
. 2024.04.22 14:05:47 - Routes, add 8000::/1 for interface "utun8".
. 2024.04.22 14:05:47 - Routes, add 199.189.27.123/32 for interface "utun8".
. 2024.04.22 14:05:48 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8".
. 2024.04.22 14:05:48 - Flushing DNS
I 2024.04.22 14:05:48 - Checking route IPv4
I 2024.04.22 14:05:48 - Checking route IPv6
I 2024.04.22 14:05:50 - Checking DNS
! 2024.04.22 14:05:50 - Connected.
. 2024.04.22 14:06:28 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #18517 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2024.04.22 14:06:28 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #18518 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2024.04.22 14:06:28 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #18519 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2024.04.22 14:07:05 - Above log line repeated 113 times more
! 2024.04.22 14:07:05 - Disconnecting
. 2024.04.22 14:07:05 - Sending soft termination signal
. 2024.04.22 14:07:06 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2024.04.22 14:07:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2024.04.22 14:07:10 - OpenVPN > Closing TUN/TAP interface
. 2024.04.22 14:07:10 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:3e16::1035
. 2024.04.22 14:07:10 - OpenVPN > delete host fde6:7a:7d20:3e16::1035
. 2024.04.22 14:07:10 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2024.04.22 14:07:10 - Routes, delete 0.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:07:10 - Routes, delete 128.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:07:10 - Routes, delete ::/1 for interface "utun8", not exists.
. 2024.04.22 14:07:10 - Routes, delete 8000::/1 for interface "utun8", not exists.
. 2024.04.22 14:07:10 - Routes, delete 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:07:10 - Routes, delete 199.189.27.123/32 for interface "utun8", not exists.
. 2024.04.22 14:07:10 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8", not exists.
. 2024.04.22 14:07:10 - Routes, delete 199.189.27.125/32 for interface "en0", not exists.
. 2024.04.22 14:07:10 - DNS of a network adapter restored to original settings (ThinkPad TBT 3 Dock, to Automatic)
. 2024.04.22 14:07:10 - DNS of a network adapter restored to original settings (USB 10/100/1000 LAN, to Automatic)
. 2024.04.22 14:07:11 - DNS of a network adapter restored to original settings (HERO10 Black, to Automatic)
. 2024.04.22 14:07:11 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2024.04.22 14:07:11 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2024.04.22 14:07:11 - DNS of a network adapter restored to original settings (Tailscale Tunnel, to Automatic)
. 2024.04.22 14:07:11 - Connection terminated.
. 2024.04.22 14:07:11 - Flushing DNS
! 2024.04.22 14:07:11 - Session terminated.
I 2024.04.22 14:08:21 - Session starting.
I 2024.04.22 14:08:21 - Checking authorization ...
! 2024.04.22 14:08:21 - Connecting to Wurren (Canada, Toronto, Ontario)
. 2024.04.22 14:08:21 - Routes, add 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:08:21 - Routes, add 199.189.27.125/32 for interface "en0", already exists.
. 2024.04.22 14:08:22 - OpenVPN > OpenVPN 2.5.5 arm-apple-darwin21.3.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2024.04.22 14:08:22 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2024.04.22 14:08:22 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.22 14:08:22 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.22 14:08:22 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.04.22 14:08:22 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.04.22 14:08:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.189.27.125:443
. 2024.04.22 14:08:22 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2024.04.22 14:08:22 - OpenVPN > UDP link local: (not bound)
. 2024.04.22 14:08:22 - OpenVPN > UDP link remote: [AF_INET]199.189.27.125:443
. 2024.04.22 14:08:22 - OpenVPN > TLS: Initial packet from [AF_INET]199.189.27.125:443, sid=7598da6c 10ebb729
. 2024.04.22 14:08:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2024.04.22 14:08:22 - OpenVPN > VERIFY KU OK
. 2024.04.22 14:08:22 - OpenVPN > Validating certificate extended key usage
. 2024.04.22 14:08:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2024.04.22 14:08:22 - OpenVPN > VERIFY EKU OK
. 2024.04.22 14:08:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Wurren, emailAddress=info@airvpn.org
. 2024.04.22 14:08:22 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2024.04.22 14:08:22 - OpenVPN > [Wurren] Peer Connection Initiated with [AF_INET]199.189.27.125:443
. 2024.04.22 14:08:22 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2024.04.22 14:08:22 - OpenVPN > Error: route: writing to routing socket: File exists
. 2024.04.22 14:08:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.66.22.1,dhcp-option DNS6 fde6:7a:7d20:3e16::1,tun-ipv6,route-gateway 10.66.22.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:3e16::1035/64 fde6:7a:7d20:3e16::1,ifconfig 10.66.22.55 255.255.255.0,peer-id 14,cipher AES-256-GCM'
. 2024.04.22 14:08:22 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2024.04.22 14:08:22 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.66.22.1'
. 2024.04.22 14:08:22 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:3e16::1'
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2024.04.22 14:08:22 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2024.04.22 14:08:22 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2024.04.22 14:08:22 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2024.04.22 14:08:22 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2024.04.22 14:08:22 - OpenVPN > Opened utun device utun8
. 2024.04.22 14:08:22 - OpenVPN > /sbin/ifconfig utun8 delete
. 2024.04.22 14:08:22 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2024.04.22 14:08:22 - OpenVPN > /sbin/ifconfig utun8 10.66.22.55 10.66.22.55 netmask 255.255.255.0 mtu 1500 up
. 2024.04.22 14:08:22 - OpenVPN > /sbin/route add -net 10.66.22.0 10.66.22.55 255.255.255.0
. 2024.04.22 14:08:22 - OpenVPN > add net 10.66.22.0: gateway 10.66.22.55
. 2024.04.22 14:08:22 - OpenVPN > /sbin/ifconfig utun8 inet6 fde6:7a:7d20:3e16::1035/64 mtu 1500 up
. 2024.04.22 14:08:22 - OpenVPN > add_route_ipv6(fde6:7a:7d20:3e16::/64 -> fde6:7a:7d20:3e16::1035 metric 0) dev utun8
. 2024.04.22 14:08:22 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:3e16:: -prefixlen 64 -iface utun8
. 2024.04.22 14:08:22 - OpenVPN > add net fde6:7a:7d20:3e16::: gateway utun8: File exists
. 2024.04.22 14:08:22 - OpenVPN > Initialization Sequence Completed
. 2024.04.22 14:08:23 - DNS of a network adapter forced (ThinkPad TBT 3 Dock, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:08:23 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:08:23 - DNS of a network adapter forced (HERO10 Black, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:08:23 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:08:23 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:08:23 - DNS of a network adapter forced (Tailscale Tunnel, from Automatic to 10.66.22.1, fde6:7a:7d20:3e16::1)
. 2024.04.22 14:08:23 - Routes, add 0.0.0.0/1 for interface "utun8".
. 2024.04.22 14:08:23 - Routes, add 128.0.0.0/1 for interface "utun8".
. 2024.04.22 14:08:23 - Routes, add ::/1 for interface "utun8".
. 2024.04.22 14:08:23 - Routes, add 8000::/1 for interface "utun8".
. 2024.04.22 14:08:23 - Routes, add 199.189.27.123/32 for interface "utun8".
. 2024.04.22 14:08:23 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8".
. 2024.04.22 14:08:23 - Flushing DNS
I 2024.04.22 14:08:23 - Checking route IPv4
I 2024.04.22 14:08:24 - Checking route IPv6
I 2024.04.22 14:08:24 - Checking DNS
! 2024.04.22 14:08:24 - Connected.
! 2024.04.22 14:08:39 - Disconnecting
. 2024.04.22 14:08:39 - Sending soft termination signal
. 2024.04.22 14:08:39 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2024.04.22 14:08:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2024.04.22 14:08:44 - OpenVPN > Closing TUN/TAP interface
. 2024.04.22 14:08:44 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:3e16::1035
. 2024.04.22 14:08:44 - OpenVPN > delete host fde6:7a:7d20:3e16::1035
. 2024.04.22 14:08:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2024.04.22 14:08:44 - Routes, delete 0.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:08:44 - Routes, delete 128.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:08:44 - Routes, delete ::/1 for interface "utun8", not exists.
. 2024.04.22 14:08:44 - Routes, delete 8000::/1 for interface "utun8", not exists.
. 2024.04.22 14:08:44 - Routes, delete 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:08:44 - Routes, delete 199.189.27.123/32 for interface "utun8", not exists.
. 2024.04.22 14:08:44 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8", not exists.
. 2024.04.22 14:08:44 - Routes, delete 199.189.27.125/32 for interface "en0", not exists.
. 2024.04.22 14:08:44 - DNS of a network adapter restored to original settings (ThinkPad TBT 3 Dock, to Automatic)
. 2024.04.22 14:08:44 - DNS of a network adapter restored to original settings (USB 10/100/1000 LAN, to Automatic)
. 2024.04.22 14:08:44 - DNS of a network adapter restored to original settings (HERO10 Black, to Automatic)
. 2024.04.22 14:08:44 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2024.04.22 14:08:44 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2024.04.22 14:08:44 - DNS of a network adapter restored to original settings (Tailscale Tunnel, to Automatic)
. 2024.04.22 14:08:44 - Connection terminated.
. 2024.04.22 14:08:44 - Flushing DNS
! 2024.04.22 14:08:44 - Session terminated.
I 2024.04.22 14:10:02 - Session starting.
I 2024.04.22 14:10:02 - Checking authorization ...
! 2024.04.22 14:10:03 - Connecting to Wurren (Canada, Toronto, Ontario)
. 2024.04.22 14:10:03 - Routes, add 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:10:03 - Routes, add 199.189.27.125/32 for interface "en0", already exists.
. 2024.04.22 14:10:03 - WireGuard > Setup start
. 2024.04.22 14:10:03 - WireGuard > Setup complete
. 2024.04.22 14:10:03 - WireGuard > Setup interface
. 2024.04.22 14:10:03 - WireGuard > Received first handshake
. 2024.04.22 14:10:04 - DNS of a network adapter forced (ThinkPad TBT 3 Dock, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:10:04 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:10:04 - DNS of a network adapter forced (HERO10 Black, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:10:04 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:10:04 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:10:04 - DNS of a network adapter forced (Tailscale Tunnel, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:10:04 - Routes, add 0.0.0.0/1 for interface "utun8".
. 2024.04.22 14:10:04 - Routes, add 128.0.0.0/1 for interface "utun8".
. 2024.04.22 14:10:04 - Routes, add ::/1 for interface "utun8".
. 2024.04.22 14:10:04 - Routes, add 8000::/1 for interface "utun8".
. 2024.04.22 14:10:04 - Routes, add 199.189.27.123/32 for interface "utun8".
. 2024.04.22 14:10:04 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8".
. 2024.04.22 14:10:04 - Flushing DNS
I 2024.04.22 14:10:04 - Checking route IPv4
I 2024.04.22 14:10:04 - Checking route IPv6
I 2024.04.22 14:10:05 - Checking DNS
. 2024.04.22 14:10:42 - Checking DNS (4° try)
. 2024.04.22 14:10:56 - Checking DNS (5° try)
E 2024.04.22 14:11:06 - Checking DNS failed, last reason: Checking DNS failed:
! 2024.04.22 14:11:06 - Disconnecting
. 2024.04.22 14:11:06 - WireGuard > Stop request received
. 2024.04.22 14:11:06 - WireGuard > Stopping
. 2024.04.22 14:11:06 - WireGuard > end
. 2024.04.22 14:11:07 - Routes, delete 0.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:11:07 - Routes, delete 128.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:11:07 - Routes, delete ::/1 for interface "utun8", not exists.
. 2024.04.22 14:11:07 - Routes, delete 8000::/1 for interface "utun8", not exists.
. 2024.04.22 14:11:07 - Routes, delete 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:11:07 - Routes, delete 199.189.27.123/32 for interface "utun8", not exists.
. 2024.04.22 14:11:07 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8", not exists.
. 2024.04.22 14:11:07 - Routes, delete 199.189.27.125/32 for interface "en0", not exists.
. 2024.04.22 14:11:07 - DNS of a network adapter restored to original settings (ThinkPad TBT 3 Dock, to Automatic)
. 2024.04.22 14:11:07 - DNS of a network adapter restored to original settings (USB 10/100/1000 LAN, to Automatic)
. 2024.04.22 14:11:07 - DNS of a network adapter restored to original settings (HERO10 Black, to Automatic)
. 2024.04.22 14:11:07 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2024.04.22 14:11:07 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2024.04.22 14:11:07 - DNS of a network adapter restored to original settings (Tailscale Tunnel, to Automatic)
. 2024.04.22 14:11:07 - Connection terminated.
I 2024.04.22 14:11:10 - Checking authorization ...
! 2024.04.22 14:11:11 - Connecting to Wurren (Canada, Toronto, Ontario)
. 2024.04.22 14:11:11 - Routes, add 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:11:11 - Routes, add 199.189.27.125/32 for interface "en0", already exists.
. 2024.04.22 14:11:11 - WireGuard > Setup start
. 2024.04.22 14:11:11 - WireGuard > Setup complete
. 2024.04.22 14:11:11 - WireGuard > Setup interface
. 2024.04.22 14:11:11 - WireGuard > Received first handshake
. 2024.04.22 14:11:12 - DNS of a network adapter forced (ThinkPad TBT 3 Dock, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:11:12 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:11:12 - DNS of a network adapter forced (HERO10 Black, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:11:12 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:11:12 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:11:12 - DNS of a network adapter forced (Tailscale Tunnel, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:11:12 - Routes, add 0.0.0.0/1 for interface "utun8".
. 2024.04.22 14:11:12 - Routes, add 128.0.0.0/1 for interface "utun8".
. 2024.04.22 14:11:12 - Routes, add ::/1 for interface "utun8".
. 2024.04.22 14:11:12 - Routes, add 8000::/1 for interface "utun8".
. 2024.04.22 14:11:12 - Routes, add 199.189.27.123/32 for interface "utun8".
. 2024.04.22 14:11:12 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8".
. 2024.04.22 14:11:12 - Flushing DNS
I 2024.04.22 14:11:12 - Checking route IPv4
I 2024.04.22 14:11:12 - Checking route IPv6
I 2024.04.22 14:11:13 - Checking DNS
. 2024.04.22 14:11:50 - Checking DNS (4° try)
. 2024.04.22 14:12:04 - Checking DNS (5° try)
E 2024.04.22 14:12:15 - Checking DNS failed, last reason: Checking DNS failed:
! 2024.04.22 14:12:15 - Disconnecting
. 2024.04.22 14:12:15 - WireGuard > Stop request received
. 2024.04.22 14:12:15 - WireGuard > Stopping
. 2024.04.22 14:12:15 - WireGuard > end
. 2024.04.22 14:12:15 - Routes, delete 0.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:12:15 - Routes, delete 128.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:12:15 - Routes, delete ::/1 for interface "utun8", not exists.
. 2024.04.22 14:12:15 - Routes, delete 8000::/1 for interface "utun8", not exists.
. 2024.04.22 14:12:15 - Routes, delete 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:12:15 - Routes, delete 199.189.27.123/32 for interface "utun8", not exists.
. 2024.04.22 14:12:15 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8", not exists.
. 2024.04.22 14:12:15 - Routes, delete 199.189.27.125/32 for interface "en0", not exists.
. 2024.04.22 14:12:15 - DNS of a network adapter restored to original settings (ThinkPad TBT 3 Dock, to Automatic)
. 2024.04.22 14:12:15 - DNS of a network adapter restored to original settings (USB 10/100/1000 LAN, to Automatic)
. 2024.04.22 14:12:15 - DNS of a network adapter restored to original settings (HERO10 Black, to Automatic)
. 2024.04.22 14:12:15 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2024.04.22 14:12:15 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2024.04.22 14:12:15 - DNS of a network adapter restored to original settings (Tailscale Tunnel, to Automatic)
. 2024.04.22 14:12:15 - Connection terminated.
I 2024.04.22 14:12:19 - Checking authorization ...
! 2024.04.22 14:12:19 - Connecting to Wurren (Canada, Toronto, Ontario)
. 2024.04.22 14:12:19 - Routes, add 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:12:19 - Routes, add 199.189.27.125/32 for interface "en0", already exists.
. 2024.04.22 14:12:19 - WireGuard > Setup start
. 2024.04.22 14:12:19 - WireGuard > Setup complete
. 2024.04.22 14:12:19 - WireGuard > Setup interface
. 2024.04.22 14:12:19 - WireGuard > Received first handshake
. 2024.04.22 14:12:20 - DNS of a network adapter forced (ThinkPad TBT 3 Dock, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:20 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:20 - DNS of a network adapter forced (HERO10 Black, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:20 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:20 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:20 - DNS of a network adapter forced (Tailscale Tunnel, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:20 - Routes, add 0.0.0.0/1 for interface "utun8".
. 2024.04.22 14:12:20 - Routes, add 128.0.0.0/1 for interface "utun8".
. 2024.04.22 14:12:20 - Routes, add ::/1 for interface "utun8".
. 2024.04.22 14:12:20 - Routes, add 8000::/1 for interface "utun8".
. 2024.04.22 14:12:20 - Routes, add 199.189.27.123/32 for interface "utun8".
. 2024.04.22 14:12:20 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8".
. 2024.04.22 14:12:20 - Flushing DNS
I 2024.04.22 14:12:20 - Checking route IPv4
! 2024.04.22 14:12:21 - Disconnecting
. 2024.04.22 14:12:21 - WireGuard > Stop request received
. 2024.04.22 14:12:21 - WireGuard > Stopping
. 2024.04.22 14:12:21 - WireGuard > end
. 2024.04.22 14:12:22 - Routes, delete 0.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:12:22 - Routes, delete 128.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:12:22 - Routes, delete ::/1 for interface "utun8", not exists.
. 2024.04.22 14:12:22 - Routes, delete 8000::/1 for interface "utun8", not exists.
. 2024.04.22 14:12:22 - Routes, delete 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:12:22 - Routes, delete 199.189.27.123/32 for interface "utun8", not exists.
. 2024.04.22 14:12:22 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8", not exists.
. 2024.04.22 14:12:22 - Routes, delete 199.189.27.125/32 for interface "en0", not exists.
. 2024.04.22 14:12:22 - DNS of a network adapter restored to original settings (ThinkPad TBT 3 Dock, to Automatic)
. 2024.04.22 14:12:22 - DNS of a network adapter restored to original settings (USB 10/100/1000 LAN, to Automatic)
. 2024.04.22 14:12:22 - DNS of a network adapter restored to original settings (HERO10 Black, to Automatic)
. 2024.04.22 14:12:22 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2024.04.22 14:12:22 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2024.04.22 14:12:22 - DNS of a network adapter restored to original settings (Tailscale Tunnel, to Automatic)
. 2024.04.22 14:12:22 - Connection terminated.
I 2024.04.22 14:12:22 - Cancel requested.
! 2024.04.22 14:12:22 - Session terminated.
I 2024.04.22 14:12:30 - Session starting.
I 2024.04.22 14:12:30 - Checking authorization ...
! 2024.04.22 14:12:30 - Connecting to Wurren (Canada, Toronto, Ontario)
. 2024.04.22 14:12:30 - Routes, add 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:12:30 - Routes, add 199.189.27.125/32 for interface "en0", already exists.
. 2024.04.22 14:12:31 - WireGuard > Setup start
. 2024.04.22 14:12:31 - WireGuard > Setup complete
. 2024.04.22 14:12:31 - WireGuard > Setup interface
. 2024.04.22 14:12:31 - WireGuard > Received first handshake
. 2024.04.22 14:12:31 - DNS of a network adapter forced (ThinkPad TBT 3 Dock, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:31 - DNS of a network adapter forced (USB 10/100/1000 LAN, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:31 - DNS of a network adapter forced (HERO10 Black, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:31 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:31 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:31 - DNS of a network adapter forced (Tailscale Tunnel, from Automatic to 10.128.0.1, fd7d:76ee:e68f:a993::1)
. 2024.04.22 14:12:31 - Routes, add 0.0.0.0/1 for interface "utun8".
. 2024.04.22 14:12:31 - Routes, add 128.0.0.0/1 for interface "utun8".
. 2024.04.22 14:12:31 - Routes, add ::/1 for interface "utun8".
. 2024.04.22 14:12:31 - Routes, add 8000::/1 for interface "utun8".
. 2024.04.22 14:12:32 - Routes, add 199.189.27.123/32 for interface "utun8".
. 2024.04.22 14:12:32 - Routes, add 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8".
. 2024.04.22 14:12:32 - Flushing DNS
I 2024.04.22 14:12:32 - Checking route IPv4
I 2024.04.22 14:12:32 - Checking route IPv6
I 2024.04.22 14:12:32 - Checking DNS
. 2024.04.22 14:13:09 - Checking DNS (4° try)
. 2024.04.22 14:13:24 - Checking DNS (5° try)
E 2024.04.22 14:13:34 - Checking DNS failed, last reason: Checking DNS failed:
! 2024.04.22 14:13:34 - Disconnecting
. 2024.04.22 14:13:34 - WireGuard > Stop request received
. 2024.04.22 14:13:34 - WireGuard > Stopping
. 2024.04.22 14:13:34 - WireGuard > end
. 2024.04.22 14:13:34 - Routes, delete 0.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:13:34 - Routes, delete 128.0.0.0/1 for interface "utun8", not exists.
. 2024.04.22 14:13:34 - Routes, delete ::/1 for interface "utun8", not exists.
. 2024.04.22 14:13:34 - Routes, delete 8000::/1 for interface "utun8", not exists.
. 2024.04.22 14:13:34 - Routes, delete 199.189.27.125/32 for interface "en0".
. 2024.04.22 14:13:34 - Routes, delete 199.189.27.123/32 for interface "utun8", not exists.
. 2024.04.22 14:13:34 - Routes, delete 2001:550:907:23:7413:852c:e946:eefa/128 for interface "utun8", not exists.
. 2024.04.22 14:13:34 - Routes, delete 199.189.27.125/32 for interface "en0", not exists.
. 2024.04.22 14:13:35 - DNS of a network adapter restored to original settings (ThinkPad TBT 3 Dock, to Automatic)
. 2024.04.22 14:13:35 - DNS of a network adapter restored to original settings (USB 10/100/1000 LAN, to Automatic)
. 2024.04.22 14:13:35 - DNS of a network adapter restored to original settings (HERO10 Black, to Automatic)
. 2024.04.22 14:13:35 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2024.04.22 14:13:35 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2024.04.22 14:13:35 - DNS of a network adapter restored to original settings (Tailscale Tunnel, to Automatic)
. 2024.04.22 14:13:35 - Connection terminated.
I 2024.04.22 14:13:38 - Checking authorization ...
Network Interfaces and Routes:
    "routes": [
            "destination": "0.0.0.0\/0",
            "expire": "",
            "flags": "UGScg",
            "gateway": "172.20.0.1",
            "interface": "en0",
            "mtu": "1500",
            "refs": "198",
            "rt_ifa": "172.20.0.25",
            "use": "38"
            "destination": "10.128\/9",
            "expire": "",
            "flags": "Uc",
            "gateway": "utun0",
            "interface": "utun0",
            "mtu": "1400",
            "refs": "2",
            "rt_ifa": "10.255.0.11",
            "use": "0"
            "destination": "100.64\/10",
            "expire": "",
            "flags": "UGSc",
            "gateway": "100.64.1.1",
            "interface": "utun3",
            "mtu": "1500",
            "refs": "1",
            "rt_ifa": "100.64.1.2",
            "use": "0"
            "destination": "100.64.1.1\/32",
            "expire": "",
            "flags": "UH",
            "gateway": "100.64.1.2",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "100.100\/22",
            "expire": "",
            "flags": "Uc",
            "gateway": "utun1",
            "interface": "utun1",
            "mtu": "1300",
            "refs": "1",
            "rt_ifa": "100.100.0.1",
            "use": "0"
            "destination": "127",
            "expire": "",
            "flags": "UCS",
            "gateway": "127.0.0.1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "127.0.0.1",
            "use": "0"
            "destination": "127.0.0.1\/32",
            "expire": "",
            "flags": "UH",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "5",
            "use": "24672595"
            "destination": "169.254\/32",
            "expire": "!",
            "flags": "UCS",
            "gateway": "link#15",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "172.20\/23",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "12",
            "use": "0"
            "destination": "172.20.0.1\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "1189",
            "flags": "UHLWIir",
            "gateway": "20:4c:3:5f:6d:e2",
            "interface": "en0",
            "mtu": "1500",
            "refs": "54",
            "use": "60"
            "destination": "172.20.0.25\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "172.20.0.73\/32",
            "expire": "1187",
            "flags": "UHLWIi",
            "gateway": "26:14:80:f5:e7:74",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "2"
            "destination": "172.20.0.117\/32",
            "expire": "!",
            "flags": "UHLWI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "172.20.0.121\/32",
            "expire": "1050",
            "flags": "UHLWI",
            "gateway": "92:55:fd:bb:b8:72",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "172.20.0.214\/32",
            "expire": "1120",
            "flags": "UHLWI",
            "gateway": "3a:d9:9:33:ae:d3",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "172.20.1.17\/32",
            "expire": "1150",
            "flags": "UHLWI",
            "gateway": "8e:92:e4:cd:e2:e4",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "172.20.1.25\/32",
            "expire": "1030",
            "flags": "UHLWI",
            "gateway": "2e:ef:7c:81:68:db",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "3"
            "destination": "172.20.1.50\/32",
            "expire": "1151",
            "flags": "UHLWI",
            "gateway": "8e:73:3f:7b:9a:ea",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "172.20.1.63\/32",
            "expire": "872",
            "flags": "UHLWI",
            "gateway": "b2:c7:ef:ec:b1:24",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "3"
            "destination": "172.20.1.98\/32",
            "expire": "1160",
            "flags": "UHLWI",
            "gateway": "1a:c8:97:ba:c9:80",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "172.20.1.127\/32",
            "expire": "1088",
            "flags": "UHLWI",
            "gateway": "46:8a:c2:bc:76:bc",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "3"
            "destination": "172.20.1.251\/32",
            "expire": "1127",
            "flags": "UHLWI",
            "gateway": "7c:57:58:bc:ff:4b",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "172.20.1.255\/32",
            "expire": "!",
            "flags": "UHLWbI",
            "gateway": "ff:ff:ff:ff:ff:ff",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "192.168.56\/32",
            "expire": "",
            "flags": "Uc",
            "gateway": "utun2",
            "interface": "utun2",
            "mtu": "1300",
            "refs": "0",
            "rt_ifa": "192.168.123.7",
            "use": "0"
            "destination": "192.168.68.12\/32",
            "expire": "",
            "flags": "Uc",
            "gateway": "utun2",
            "mtu": "1300",
            "refs": "0",
            "use": "0"
            "destination": "192.168.68.13\/32",
            "expire": "",
            "flags": "Uc",
            "gateway": "utun2",
            "mtu": "1300",
            "refs": "0",
            "use": "0"
            "destination": "192.168.123\/32",
            "expire": "",
            "flags": "Uc",
            "gateway": "utun2",
            "mtu": "1300",
            "refs": "1",
            "use": "4"
            "destination": "224.0.0\/4",
            "expire": "!",
            "flags": "UmCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "use": "0"
            "destination": "224.0.0.251\/32",
            "expire": "",
            "flags": "UHmLWI",
            "gateway": "1:0:5e:0:0:fb",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "239.255.255.250\/32",
            "expire": "",
            "flags": "UHmLWI",
            "gateway": "1:0:5e:7f:ff:fa",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "43"
            "destination": "255.255.255.255\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "::\/0",
            "expire": "",
            "flags": "UGcIg",
            "gateway": "fe80::",
            "interface": "utun4",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::3ba:6e45:f993:9929%utun4",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun5",
            "mtu": "1380",
            "refs": "0",
            "rt_ifa": "fe80::5b63:2e3c:1a4:179%utun5",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun6",
            "mtu": "2000",
            "refs": "0",
            "rt_ifa": "fe80::5da:da14:992:d3e3%utun6",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun7",
            "mtu": "1000",
            "refs": "0",
            "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun7",
            "use": "0"
            "destination": "::1\/128",
            "expire": "",
            "flags": "UHL",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "::1",
            "use": "492439"
            "destination": "fe80::\/64",
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "fe80::1%lo0",
            "use": "0"
            "destination": "fe80::1\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "81"
            "expire": "",
            "flags": "UCI",
            "gateway": "link#14",
            "interface": "ap1",
            "mtu": "1500",
            "refs": "1",
            "rt_ifa": "fe80::f4d4:88ff:fe81:3132%ap1",
            "use": "0"
            "destination": "fe80::f4d4:88ff:fe81:3132\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "f6:d4:88:81:31:32",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "rt_ifa": "fe80::1045:7b7f:5423:2879%en0",
            "use": "0"
            "destination": "fe80::1045:7b7f:5423:2879\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "f4:d4:88:81:31:32",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "use": "0"
            "destination": "fe80::1870:2197:87c4:f7a8\/128",
            "expire": "",
            "flags": "UHLWIi",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "2"
            "destination": "fe80::8b:29ff:fe9a:9e6f\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "2:8b:29:9a:9e:6f",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "fe80::8b:29ff:fe9a:9e6f%awdl0",
            "use": "0"
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "fe80::8b:29ff:fe9a:9e6f%llw0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::3ba:6e45:f993:9929",
            "mtu": "1500",
            "refs": "2",
            "use": "0"
            "destination": "fe80::3ba:6e45:f993:9929\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#22",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::5b63:2e3c:1a4:179",
            "mtu": "1380",
            "refs": "2",
            "use": "0"
            "destination": "fe80::5b63:2e3c:1a4:179\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#23",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::5da:da14:992:d3e3",
            "mtu": "2000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::5da:da14:992:d3e3\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#24",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::ce81:b1c:bd2c:69e",
            "mtu": "1000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::ce81:b1c:bd2c:69e\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#25",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "destination": "ff00::\/8",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "ap1",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#16",
            "interface": "awdl0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::c81d:abff:fe5f:7d20%awdl0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#17",
            "interface": "llw0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::c81d:abff:fe5f:7d20%llw0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "destination": "ff01::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "ap1",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
            "destination": "ff02::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "ap1",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1000",
            "refs": "0",
            "use": "0"
    "ipv4-default-gateway": "172.20.0.1",
    "ipv4-default-interface": "en0",
    "ipv6-default-gateway": "fe80::",
    "ipv6-default-interface": "utun4",
    "interfaces": [
            "friendly": "lo0",
            "id": "lo0",
            "name": "lo0",
            "description": "lo0",
            "type": "Loopback",
            "status": "Up",
            "bytes_received": "0",
            "bytes_sent": "0",
            "support_ipv4": true,
            "support_ipv6": true,
            "ips": [
                "127.0.0.1",
                "::1",
                "fe80::1"
            "bind": true
            "friendly": "gif0",
            "id": "gif0",
            "name": "gif0",
            "description": "gif0",
            "type": "Unknown",
            "status": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "stf0",
            "id": "stf0",
            "name": "stf0",
            "description": "stf0",
            "type": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi0",
            "id": "anpi0",
            "name": "anpi0",
            "description": "anpi0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi1",
            "id": "anpi1",
            "name": "anpi1",
            "description": "anpi1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "anpi2",
            "id": "anpi2",
            "name": "anpi2",
            "description": "anpi2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en4)",
            "id": "en4",
            "name": "en4",
            "description": "en4",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en5)",
            "id": "en5",
            "name": "en5",
            "description": "en5",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet Adapter (en6)",
            "id": "en6",
            "name": "en6",
            "description": "en6",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 1",
            "id": "en1",
            "name": "en1",
            "description": "en1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 2",
            "id": "en2",
            "name": "en2",
            "description": "en2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 3",
            "id": "en3",
            "name": "en3",
            "description": "en3",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt Bridge",
            "id": "bridge0",
            "name": "bridge0",
            "description": "bridge0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "ap1",
            "id": "ap1",
            "name": "ap1",
            "description": "ap1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::f4d4:88ff:fe81:3132"
            "bind": true
            "friendly": "Wi-Fi",
            "id": "en0",
            "name": "en0",
            "description": "en0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::1045:7b7f:5423:2879",
                "172.20.0.25"
            "bind": true
            "friendly": "awdl0",
            "id": "awdl0",
            "name": "awdl0",
            "description": "awdl0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::8b:29ff:fe9a:9e6f"
            "bind": true
            "friendly": "llw0",
            "id": "llw0",
            "name": "llw0",
            "description": "llw0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun0",
            "id": "utun0",
            "name": "utun0",
            "description": "utun0",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "10.255.0.11"
            "bind": true
            "friendly": "utun1",
            "id": "utun1",
            "name": "utun1",
            "description": "utun1",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "100.100.0.1"
            "bind": true
            "friendly": "utun2",
            "id": "utun2",
            "name": "utun2",
            "description": "utun2",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "192.168.123.7"
            "bind": true
            "friendly": "utun3",
            "id": "utun3",
            "name": "utun3",
            "description": "utun3",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "100.64.1.2"
            "bind": true
            "friendly": "utun4",
            "id": "utun4",
            "name": "utun4",
            "description": "utun4",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun5",
            "id": "utun5",
            "name": "utun5",
            "description": "utun5",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun6",
            "id": "utun6",
            "name": "utun6",
            "description": "utun6",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun7",
            "id": "utun7",
            "name": "utun7",
            "description": "utun7",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
ifconfig:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
    options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
    inet 127.0.0.1 netmask 0xff000000
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=400<CHANNEL_IO>
    ether <redacted>
    media: none
    status: inactive
anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    media: none
    status: inactive
anpi2: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    media: none
    status: inactive
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    media: none
    status: inactive
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    media: none
    status: inactive
en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    media: none
    status: inactive
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    options=460<TSO4,TSO6,CHANNEL_IO>
    ether <redacted>
    media: autoselect <full-duplex>
    status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=63<RXCSUM,TXCSUM,TSO4,TSO6>
    ethe <redacted>
    Configuration:
        id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
        maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
        root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
        ipfilter disabled flags 0x0
    member: en1 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 10 priority 0 path cost 0
    member: en2 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 11 priority 0 path cost 0
    member: en3 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 12 priority 0 path cost 0
    media: <unknown type>
    status: inactive
ap1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
    ether <redacted>
    inet6 fe80::f4d4:88ff:fe81:3132%ap1 prefixlen 64 scopeid 0xe
    media: autoselect (<unknown type>)
    status: inactive
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    inet6 fe80::1045:7b7f:5423:2879%en0 prefixlen 64 secured scopeid 0xf
    inet 172.20.0.25 netmask 0xfffffe00 broadcast 172.20.1.255
    media: autoselect
    status: active
awdl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    inet6 fe80::8b:29ff:fe9a:9e6f%awdl0 prefixlen 64 scopeid 0x10
    media: autoselect
    status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether <redacted>
    inet6 fe80::8b:29ff:fe9a:9e6f%llw0 prefixlen 64 scopeid 0x11
    media: autoselect
    status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1400
    inet 10.255.0.11 --> 20.18.19.0 netmask 0xff000000
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1300
    inet 100.100.0.1 --> 20.18.20.0 netmask 0xff000000
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1300
    inet 192.168.123.7 --> 20.18.21.0 netmask 0xffffff00
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
    inet 100.64.1.2 --> 100.64.1.1 netmask 0xffc00000
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
    inet6 fe80::3ba:6e45:f993:9929%utun4 prefixlen 64 scopeid 0x16
utun5: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::5b63:2e3c:1a4:179%utun5 prefixlen 64 scopeid 0x17
utun6: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
    inet6 fe80::5da:da14:992:d3e3%utun6 prefixlen 64 scopeid 0x18
utun7: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
    inet6 fe80::ce81:b1c:bd2c:69e%utun7 prefixlen 64 scopeid 0x19
utun8: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1420
    inet 10.191.195.102 --> 10.191.195.102 netmask 0xff000000
    inet6 fe80::f6d4:88ff:fe81:3132%utun8 prefixlen 64 scopeid 0x20
    inet6 fd7d:76ee:e68f:a993:e127:fa3f:d44b:7d3a prefixlen 64
Edited ... by acute-playpen-downy-qatar
Can you please test Eddie 2.24.2 beta and check whether the problem persists or gets resolved? Please see here to download the latest beta version:
https://airvpn.org/forums/topic/57401-eddie-desktop-224-beta-released/
