183aTr78f9o
ANSWERED Logging in takes about 45 seconds
I've noticed that logging in takes about 45 seconds. This started to occur today, it's usually almost instant.
On two different Linux distributions with AirVPN Suite 1.3.0:
2024-04-08 16:17:31 Logging in AirVPN user 183aTr78f9o
2024-04-08 16:18:16 AirVPN user 183aTr78f9o successfully logged in
2024-04-08 17:08:53 Logging in AirVPN user 183aTr78f9o
2024-04-08 17:09:38 AirVPN user 183aTr78f9o successfully logged in
I also observe the same delay with Eddie for Android 3.0 after rebooting my phone. Logging on AirVPN website with my account is fine, no issue whatsoever.
Anyone else?
Problem confirmed and under investigation. It is caused by an unexpected sluggishness of the first bootstrap server. If the first bootstrap server fails, Eddie will try the second one (timeout: 45 seconds), and then the third one (again 45 seconds timeout) and so on, so everything will work although the initial connection gets delayed.
EDIT: problem solved.
