KingBletsoe 0 Posted ... Hello I'm having trouble port-forwarding when it comes to TCP i keep getting (connection timed 110) UDP is fine wondering if anyone had any insight to my problem Quote Share this post Link to post
Staff 10464 Posted ... @KingBletsoe Hello! A preliminary checklist: please make sure that the listening program is really running and listening to the correct port, and that it is started only after the VPN connection has been established if a bind option is available in the listening program settings please make sure that the program binds to the VPN interface and not to the physical network interface please make sure that no firewall rule blocks incoming packets to the listening program. You need to check while the system is connected to the VPN as some firewall tools change rule set according to the network type the system is connected to Kind regards Quote Share this post Link to post
