Moneytinker
ANSWERED Problem with alien VPN interface
. 2024.02.27 13:59:16 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system.  You should be able to create an adapter by using tapctl.exe utility.
. 2024.02.27 13:59:16 - OpenVPN > Exiting due to fatal error
! 2024.02.27 13:59:16 - Disconnecting
. 2024.02.27 13:59:33 - Using WinTun network interface "Local Area Connection 2 (Private Internet Access Network Adapter)"
. 2024.02.27 13:59:39 - OpenVPN > There are no TAP-Windows nor Wintun adapters on this system.  You should be able to create an adapter by using tapctl.exe utility.
. 2024.02.27 13:59:39 - OpenVPN > Exiting due to fatal error
