I have a docker swarm running a gluetun container. The logs show that I am getting an IP and the my port forward is open. I then have a second a container running with transmission. Due to the design of docker swarm it seems that I cannot  connect transmission directly to the gluetun container leaving me to connect to it via http proxy. In the transmission container I have set the peerport to my ford port#. I can also run curl ifconfig.io and it returns my airVPN ip. Netstat shows me that the forward port is open on both containers.
When I open the UI for transmission and go into preferences it says the port is closed and AirVPN shows it unreachable.
Suggestions?
Nope...had to give up on docker swarm.  Just running all my pis independently. (Seems docker swarm is no longer being supported or developed.)
