castlkng
ANSWERED First time user, not connecting
Trying this out, unable to connect to any servers. I've tried a few different protocols as recommended in other threads, as well as changing VPN interface name to eddie (doesn't seem to be the issue, anyway).  Any ideas? Much appreciated!
. 2024.02.23 23:03:52 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.19045.0, Mono/.Net: v4.0.30319
. 2024.02.23 23:03:52 - Command line arguments (1): path="home"
. 2024.02.23 23:03:53 - Reading options from C:\Users\PC\AppData\Local\Eddie\default.profile
. 2024.02.23 23:03:53 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2024.02.23 23:03:53 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2024.02.23 23:03:53 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2024.02.23 23:03:54 - Ready
. 2024.02.23 23:03:55 - Collect information about AirVPN completed
I 2024.02.23 23:04:14 - Session starting.
I 2024.02.23 23:04:16 - Checking authorization ...
! 2024.02.23 23:04:16 - Connecting to Castor (Belgium, Brussels)
. 2024.02.23 23:04:17 - Routes, add 91.207.57.117/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2024.02.23 23:04:17 - Routes, add 91.207.57.117/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)", already exists.
. 2024.02.23 23:04:17 - WireGuard > Setup start
. 2024.02.23 23:04:17 - WireGuard > Setup complete
. 2024.02.23 23:04:17 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.19045; amd64)
. 2024.02.23 23:04:17 - WireGuard > Watching network interfaces
. 2024.02.23 23:04:17 - WireGuard > Resolving DNS names
. 2024.02.23 23:04:17 - WireGuard > Creating network adapter
. 2024.02.23 23:04:17 - WireGuard > Using existing driver 0.10
. 2024.02.23 23:04:17 - WireGuard > Creating adapter
. 2024.02.23 23:04:17 - WireGuard > Using WireGuardNT/0.10
. 2024.02.23 23:04:17 - WireGuard > Eddie build 2
. 2024.02.23 23:04:17 - WireGuard > Dropping privileges
. 2024.02.23 23:04:17 - WireGuard > Interface created
. 2024.02.23 23:04:17 - WireGuard > Setup interface
. 2024.02.23 23:04:17 - WireGuard > Setting interface configuration
. 2024.02.23 23:04:17 - WireGuard > Peer 1 created
. 2024.02.23 23:04:17 - WireGuard > Monitoring MTU of default v6 routes
. 2024.02.23 23:04:17 - WireGuard > Interface up
. 2024.02.23 23:04:17 - WireGuard > Setting device v6 addresses
. 2024.02.23 23:04:17 - WireGuard > Monitoring MTU of default v4 routes
. 2024.02.23 23:04:17 - WireGuard > Setting device v4 addresses
. 2024.02.23 23:04:17 - WireGuard > Startup complete
. 2024.02.23 23:04:22 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 2)
. 2024.02.23 23:04:27 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 2)
. 2024.02.23 23:04:33 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 2)
. 2024.02.23 23:04:43 - Above log line repeated 1 times more
. 2024.02.23 23:04:43 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 3)
. 2024.02.23 23:04:48 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 4)
. 2024.02.23 23:04:53 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 2)
. 2024.02.23 23:04:58 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 3)
. 2024.02.23 23:05:03 - WireGuard > Handshake for peer 1 (91.207.57.117:51820) did not complete after 5 seconds, retrying (try 4)
W 2024.02.23 23:05:08 - WireGuard > Handshake timeout
! 2024.02.23 23:05:08 - Disconnecting
. 2024.02.23 23:05:08 - WireGuard > Stop request received
. 2024.02.23 23:05:08 - WireGuard > Stopping
. 2024.02.23 23:05:09 - WireGuard > Completed
. 2024.02.23 23:05:09 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2024.02.23 23:05:09 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2024.02.23 23:05:09 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2024.02.23 23:05:09 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2024.02.23 23:05:09 - Routes, delete 91.207.57.117/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)".
. 2024.02.23 23:05:09 - Routes, delete 91.207.57.115/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2024.02.23 23:05:09 - Routes, delete 2001:ac8:27:f:c0ca:9f36:68ed:1e70/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2024.02.23 23:05:09 - Routes, delete 91.207.57.117/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)", not exists.
. 2024.02.23 23:05:09 - Connection terminated.
I have also tried these steps recommended in another thread with no success, in various regions and protocols:
Quote
Apparently either UDP packets or OpenVPN are blocked. Please check any packet filtering tool both on your system and router. On the router check any "Quality of Service" or "traffic management" tool as well.  Also, test a connection through WireGuard. It works only in UDP so if it can connect successfully then you know that the block is OpenVPN or port specific, and not against UDP in general. To have Eddie switch to WireGuard:
  • from Eddie's main window please select "Preferences" > "Protocols"
  • uncheck "Automatic"
  • select any line with WireGuard, for example WireGuard port 51820. The line will be highlighted.
  • click "Save" and re-start a connection to apply the change
  • please make sure to test a few servers in different locations around your node
It's trying to use the Radmin interface. Uninstall it or follow:.
