johnzc
ANSWERED Problem on Chromebook, certificate import not hardware-backed
Hi - I'm trying to set up the VPN on a chromebook using this guide https://airvpn.org/chromeos/
All seems fine except when I import the cert there is no indication of 'hardware-backed'.
When I try to connect to the VPN it gets stuck on 'Connecting ...'
Any pointers would be appreciated, thanks.
EDIT: after a while I get DNS lookup failed error
EDIT2: I've been using Eddie client on PC since 2012.
Edited ... by johnzc
