xistal_ 0 Posted ... Whenever I connect, it hangs on checking IPv4 until I manually cancel attempting to connect. I've tried multiple fixes from various other threads and nothing seems to work. Logs attached below. Thank you! Eddie_20240128_173316.txt Quote Share this post Link to post
Staff 10711 Posted ... Hello! The following errors thrown by OpenVPN: . 2024.01.28 17:17:24 - OpenVPN > write UDP: Unknown error (code=10065) . 2024.01.28 17:17:24 - OpenVPN > write UDP: Unknown error (code=10065) . 2024.01.28 17:17:24 - OpenVPN > write UDP: Unknown error (code=10065) hint to something blocking UDP and/or OpenVPN packets. Please check any packet filtering and traffic management tools both on your system and router and make sure you remove any such block. Also test a connection over WireGuard to discern whether the block is against UDP or against OpenVPN specifically. To switch to WireGuard: from Eddie's main window please select "Preferences" > "Protocols" uncheck "Automatic" select any line with WireGuard. The line will be highlighted. click "Save" and re-start a connection to apply the change Please make sure to test various servers in different locations. Kind regards Quote Share this post Link to post
