Does the same problem persist if you try a connection via WireGuard? In order to switch to WireGuard:
  • from Eddie's main window please select "Preferences" > "Protocols"
  • uncheck "Automatic"
  • select any line with WireGuard. The line will be highlighted.
  • click "Save" and re-start a connection to apply the change
  • please make sure to test a few servers in different locations around your node
Let's verify whether the route check failure is a false positive or not:
  • from Eddie's main window select "Preferences" > "Advanced"
  • uncheck "Check if the VPN tunnel works"
  • click "Save"
  • enable Network Lock from Eddie's main window
  • select "Preferences" > "DNS"
  • uncheck "Check Air VPN DNS"
  • click "Save"
  • test again connections with WireGuard and OpenVPN. This time the connection should be fine from the log, but you must verify manually that you can perform your normal Internet activity. Network Lock will prevent anyway any traffic leak and make the route check superfluous
