Xp5
My review on AirVPN.
If someone else wanted a decent VPN, I'd direct them to this. So far of a month usage, AirVPN never created any issues.
The port forwarding instruction was a bit confusing, as I was not sure If I should configure port forwarding in my router,
Maybe more detailed steps would be appreciated (the answer is don't configure, VPN will work without router configs)
About speeds, I always reach around 5/6 my speed (to keep it simple, I reach max speed).
Using WireGuard, in a Linux machine.
A happy customer, will renew subscription.
Edit: Oh, my bad. I forgot to credit AirVPN staffs, they are helpful in forums.
Edited ... by Xp5
Credit
