user994
ANSWERED login failed wrong login/password
I am getting the error "login failed wrong login/password" when I try to login on android using eddie.  It's the same login/password that works here and on the linux version of eddie.
It might be a known Eddie Android edition bug (whose fix is planned on the next release): if your access credentials include the % character the credentials will not be processed properly and you will get an error message (however, the error message you report comes from Eddie Desktop edition, but basically that's the same meaning). Might it be the case?
 It worked when I used my email to login.  I was using a hard password to type on the phone too so it might have been user error.  Thanks for your help!
