SeUbHS
ANSWERED Slow connection speed regardless of server?
I've been noticing slower loading pages for about a month or better now across multiple large websites like reddit. My logs are attached below.
logs.txt
Do you get any improvement with WireGuard? In order to switch to WireGuard:
  • from Eddie's main window please select "Preferences" > "Protocols"
  • uncheck "Automatic"
  • select any line with WireGuard. The line will be highlighted.
  • click "Save" and re-start a connection to apply the change
  • please make sure to test a few servers in different locations around your node
Thanks, I swapped protocol to wireguard. It seems ok right now, but the issue isn't 100% of the time, so I'll have to monitor the situation over time. edit: I haven't noticed this issue for a while now, so I'm marking this as solved.
