Not connected, Your IP: 216.73.216.190
OPN-UserGuide
ANSWERED [Resolved] OPNSense WireGuard configuration questions.
Hi everyone,
I did follow the guide posted here: [link] as good as I could. I ran ins some minor issues, but that should not be the root cause really.
Furthermore, I documented my setup and posted a reply to the original author this time with screenshots so it could be used as help for everyone, like me, who is struggling with this.
So as said, basically it's not working for me. I can't access anything from LAN. To me (noob) it looks like the tunnel is up, but I can't reach it.
Looking at the gateway shows "defunct". To me, this does not sound good.
In the WireGuard log, I get the following when I disable WireGuard and enable it again:
I am a complete starter on OPNsense and WireGuard, before I was using pfSense and OpenVPN, but this is a bit different. So any help is much appreciated.
Edited ... by OPN-UserGuide
resolved
since we do not know your setup at all or if you utilize ip6 at your place
click the edit next to wan_dhcp6 and wan_wg_gw.  and click disabled = check
reboot your box and see if your standard connection starts working again
No sure if you read my posting at all, but I got a clear step-by-step guide posted above.
Anyway, I found the issue myself and documented in.
Thanks for the effort.
