MasterExploder 0 Posted ... I've been using Eddie sporadically for a while now. Recently, I've been unable to connect, though. Eddie will attempt to connect to a server, before timing out and retrying with another server. This will repeat. I'm not sure how to fix. Here are my most recent logs:https://eddie.website/report/b804e8d7/ Share this post Link to post
Staff 10319 Posted ... Hello! We see two different problems. Please see here for an explanation and a quick solution of the first problem:https://airvpn.org/forums/topic/56657-cant-connect-to-anything/?do=findComment&comment=225418 The second problem seems related to IPv6. Maybe your ISP does not support it, or the first problem is causing the second one too. If the solution to the first problem does not solve the second one, please go back to the default setting. You have forced Eddie to connect over IPv6 in "Preferences" > "Networking" window. Switch the "Protocol used for connection" combo box back to "IPv4, IPv6" (currently you have set it to "IPv6, IPv4"). Kind regards Share this post Link to post
